Left turn signal dash light
Old Jan 16, 2023 | 03:54 PM
Romad's Avatar
Default Left turn signal dash light
'06 Xfire: My left and right turn signals work just fine. However the left turn signal dash light indicator not illuminating. When I turn the left turn signal on I hear no "click click" but the front and rear signals work. The right turn signal "clicks" when turned on. Are they on different relays or fused separately or do I just have a burnt out left indicator bulb? You know I don't want to remove the dash for a dang burnt out light bulb!!!!!
Old Jan 16, 2023 | 05:28 PM
Default Re: Left turn signal dash light
I think the "click" is generated electronically by the signal that feeds those green turn signal lights. It is possible that changing that indicator will make current flow and generate the 'click'.
It is also possible that the connection form the console switch group to the instrument panel is bad. ON the back of the instrument panel, check for pulsing voltage at C1 pin 1A with the turn signal activated.
If you see no pulse, the issue is in the console switch group or harness. If you see the pulse, the problem is in the Instrument panel.
Old Jan 16, 2023 | 05:57 PM
Romad's Avatar
I ON the back of the instrument panel, check for pulsing voltage at C1 pin 1A with the turn signal activated. If you see no pulse, the issue is in the console switch group or harness. If you see the pulse, the problem is in the Instrument panel.
Uh oh! Sounds like the dash has to be removed! How about I just ignore it, as I have for the past 4 months, and just remember to turn off the signal when making a left lane change or other drivers honking at me all the time! LOL
Thanks once again Pizzaguy!
Old Feb 11, 2024 | 05:01 PM
cyrus06cf's Avatar
I have the same exact problem
I did remove the cluster and I did change the bulb, still not working.
I was into the dash to remedy the Sticky key" problem so the cluster was easy to get to.
IMHO learn to live with it guys.
So many plastic parts cracked on me a lot of frustration and no remedy anyhow.
sheldon
Old Feb 12, 2024 | 01:36 AM
JSK's Avatar
JSK
I’m curious if the indicator flashes with the 4ways.
Old Feb 12, 2024 | 06:42 AM
cyrus06cf's Avatar
The indicator does not flash w 4 ways either
Its annoying, however every once in a while I test it behind another vehicle when I can see the flash reflecting
Miss the old school metal flashers for 4$ that popped out in 1 sec and hung down openly beneath the dash
Old Feb 12, 2024 | 09:38 AM
Romad's Avatar
Yes that's the same thing I've been doing for a long time now. When I get stopped behind another vehicle, and making a left turn, I always look for a reflection. ( We have learned to overcome! Ha ha)
Old Feb 12, 2024 | 01:13 PM
I'm getting the idea that BCMs are starting to fail in our fleet. For my first twelve years here, no such failures were known on the forum. Cant say that anymore, this is at least the third issue related to a BCM since I moved to Arkansas in 2020.
Old Feb 12, 2024 | 01:59 PM
cyrus06cf's Avatar
BCM? I do not know what that is?
Blinker control module? please dont laugh
can it be changed?
Old Feb 12, 2024 | 02:05 PM
Ronman's Avatar
There was at least one failure before 2020, someone heard clicking from their BCM and when they opened it up there was a burned contact. I don't remember what issue they had though.
Old Feb 12, 2024 | 02:10 PM
Romad's Avatar
The hardest thing, for me, is if it's necessary to remove the dash bezel having to remove the panel above the floorboard. At 76 my body just doesn't contort like it used too! It I have to remove the dash "again" I just won't put it back on. All that just to get at two screws if I remember correctly. I did do something to help with bezel removal on my '05 XF which I broke and repaired. At top of the bezel's back side there are two long mounting "teeth" that have to be lifted way up to remove the bezel. Well that's what caused me to break my brittle bezel. I cut off about 1/3 or so of the two "teeth" so it doesn't have to go up so high and stressing the plastic.
Old Feb 12, 2024 | 02:17 PM
Romad's Avatar
can it be changed?
I think it's the Body control Module. I just found a YouBoob video on where it is and how to remove.
Old Feb 13, 2024 | 07:31 AM
cyrus06cf's Avatar
my bezel did not break however the knee panel is now literally in pieces
I used super glue gel for some....
Yes, it is tight under there!
Old Feb 13, 2024 | 07:34 AM
cyrus06cf's Avatar
Eye-ma just going to live with it for now
thanks guys
Old Feb 13, 2024 | 01:08 PM
The BCM is Body Control Module - it runs the wipers, turn signals, and handles a lot of communications between SKREEM and CLP/SSM and also processes switch inputs from the console switches and passes this information to the various modules in the car. The BCM plays a role in some, but not all, CAN BUS signalling. The BCM tells the top module if the retainer latch switch is open or closed, and if the windows are going down properly..
The BCM is in the middle of a LOT of what is going on with the car....
Old Feb 13, 2024 | 01:10 PM
cyrus06cf's Avatar
wow thank you so much!
clarification achieved
sheldon
2006 limited convertible
89,000 miles
Purchased from a friend who was in need of cash, and absolutely fell in love with this machine.
Romad
Feb 11, 2021 10:18 PM
brad4cad
Mar 24, 2013 07:24 PM
brad4cad
Mar 22, 2013 10:13 AM
D&D
Jun 27, 2007 09:34 PM
D&D
Jun 27, 2007 09:27 PM
