Bad fuse?
Old Oct 16, 2023 | 04:51 PM
Twieg1235's Avatar
Default Bad fuse?
Got on the car last week and the cluster lit up like a Christmas tree, abs light, bas esp, e brak light, brake light, check engine light all came on. All gauges work except the speedometer, traction control isn’t working, and the spoiler won’t go down. I’m not gonna lie tho, maybe I’m wrong but it feels like it’s making more power
Old Oct 16, 2023 | 07:08 PM
Default Re: Bad fuse?
THe the power feed to the Brake Controller has failed. This is either the fuse on the RCM, the Traction Control Relay on the RCM or fractured solder connections on the RCM.
What I would do:
1) Order a new RCM, put it in and be happy. ($140-165 depending on where you buy it.)
2) Take old RCM, put in box, ship to DJ for reworking ($65, shipping back to you included).
THIS way, the next time the RCM fails, and they WILL fail eventually, you have a spare in the trunk. Like I do, cause 1) and 2) is exactly what I did when mine failed.
Order this one: (And the website tells you it wont fit the Crossfire; the website is wrong.)
https://www.autohausaz.com/pn/142602...RoCDi0QAvD_BwE
Old Oct 16, 2023 | 11:19 PM
What I would do:
The solder joints are not fractured, they are dry joints because the parts were not heated high enough or there was a dirty surface.
What would make them fracture as any vibrations are the same for both sides of the joint.
GraphiteGhost
Jun 9, 2017 01:49 AM
crookedview
May 5, 2014 11:01 PM
blackoutken
Jun 8, 2011 11:27 AM
Don Hiltz
Jul 5, 2009 03:13 PM
Don Hiltz
May 2, 2009 11:50 PM
