Driving on freeway and the car just died, cranks but no start
I already changed the sensor as well, I even bought a new rcm to see if that was the problem still only cranks but no start
Have you checked for codes?
I bought a brand new RCM, I installed a new Bosch Crankshaft and Camshaft sensors and my car will not start. It attempts to crank but it doesn't start, there's no codes, also changed fuel pump
You have not stated the condition of the battery. Also, did you change the gas filter or just the pump? And have you checked the fuses to see if any are bad?
Yes I even went to autozone to check the battery and battery was perfect, I changed everything fuel pump and filter, I haven’t check any fuzes though any suggestions on which one?
The only fuse for the fuel pump is the one on the RCM as far as I know. See the picture below for details.
True, it might not be the RCM, but you should check if the connectors are on tight, the fuses are okay, or if the wires aren't frayed. Sometimes it's the simple things that get us. My car started running badly and it turned out to be one of the connectors on a fuel injector had come loose. Not sure how that happened, but I snapped it back in, and I was good to go.
-Jerry
-Jerry
You may check the crankshaft position sensor to be sure its completely clean and seated. I replaced mine and the car would quit at 4000 rpm. I put the original one back in and plugged, unplugged and replugged it until I was positive it had a secure connection. It's still in there.
Les
Les
Something I learned the hard way on several occasions is just because you bought a new part, it doesn't mean it's good. Brand new parts right out of the box can be bad. Just a suggestion.
I already tested the part and guess what It didn’t have any problem
) thanks for all your help I’ll just keep looking till it turns on
I just spent $411 on a Mercedes refurbished part from Mercedes dealership that was bad for my wife's CLK500. Frustration isn't the half of IT.
HamdyHand
Oct 12, 2021 03:38 PM
Davgord
28
Jun 5, 2017 09:48 AM
