What is this wire for ?
Old Mar 10, 2025 | 11:04 AM
Dave62's Avatar
Default What is this wire for ?
2004 6spd 46k miles.
While driving dash lit up, cel, brake wear, abs, brake,bas/esp. Car runs great as is. Code 600.
this is the box next to the battery. Is it not used purposely or what is it supposed to go to?
Green wire comes into the box on its own, the sleeve its in contains only one wire. It leads to the back wall and travels down behind the battery then I lose it. Does it have anything to do with the code 600 problem?
Old Mar 10, 2025 | 11:09 AM
Default Re: What is this wire for ?
How long have you owned it?
Old Mar 10, 2025 | 11:16 AM
Dave62's Avatar
since jan. 2025.
Old Mar 10, 2025 | 11:37 AM
How was it running, starting after the lights came on?
Old Mar 10, 2025 | 11:57 AM
Dave62's Avatar
It was running great both before and now 3000 miles later.
Old Mar 10, 2025 | 06:21 PM
Check to see if there are any connectors with a connector in them but no wire. Maybe you will spot one with some of that green insulation.
Old Mar 11, 2025 | 12:35 AM
P0600?
That is a generic (and unhelpful) code that means there is an issue on the CAN BUS. And those lights coming on also indicate that the modules are having trouble talking to one another.
That wire looks like it was added for some accessory that someone added or was going to add to the car. I doubt it's related to the problems you listed.
Tell me this - is the speedometer working when you are driving along?
How old is the battery?
When starting the car, does the starter turn the engine over kinda slowly?|
How do the battery cables/clamps look?
Have you jump started the Crossfire? Have you used the Crossfire to jump start another vehicle? (A "yes" to either question would be a very bad answer.)
Old Mar 14, 2025 | 08:42 PM
Dave62's Avatar
DJ Tighe has some excellent videos on YouTube.
props .
the traction control relay failed on the rcm board.
DJ refurbished one and sent it to me. We are so lucky to have people like him to help us.
eazy peazy repair thanks to DJ.
Old Mar 15, 2025 | 01:36 AM
props .
Thank you for letting us know what the problem was.
Mr. Max
Aug 11, 2021 08:18 PM
Mackel
Apr 13, 2015 07:50 PM
Romio
Jun 15, 2009 03:02 PM
nox1s
Jul 12, 2007 07:34 PM
DFWSBR
Apr 29, 2004 07:07 PM
