Whining Noise coming from trunk/rear tires area
Old Mar 11, 2025 | 08:32 PM
wlkDwlk's Avatar
Unhappy Whining Noise coming from trunk/rear tires area
We suddenly have a whining noise when the car is running. We can only pinpoint it to the trunk/rear tire area. It's continuous as if there's a motor or something running. The convertible top goes up and down without issue. The back fin opens and closes without issue. Any ideas of what it could be?
Old Mar 12, 2025 | 08:38 AM
Default Re: Whining Noise coming from trunk/rear tires area
Fuel pump?
Old Mar 12, 2025 | 08:50 AM
zip439's Avatar
The way you make your statement as to the car "running" I assume the noise is present even when stopped, not moving down the road, but the engine is running?
With the car running and you hear the noise pull the fuses that power the hydraulic top and those associated with security system. When the noise stops you found your problem.
Old Mar 12, 2025 | 01:19 PM
When your pulling fuse(s) troubleshooting, don't forget the vacuum pump for the doors/trunk in the lower bay under all the trim, etc.
Old Mar 12, 2025 | 04:36 PM
wlkDwlk's Avatar
We DID just have the gas tank gasket replaced because it was leaking gas.
Old Mar 13, 2025 | 01:39 AM
Was the fuel pump replaced as well?
Some of the cheaper pumps are noisy.
Old Mar 13, 2025 | 08:15 AM
wlkDwlk's Avatar
It wasn't part of the quoted work, but we are going to ask the mechanic to look into it. The car doesn't get driven often or for long distances (it only has 14k original miles) so anything is possible but, like I said, we just got it back from the mechanic for the gas tank so it just seems like that could be the connection and since you brought up the fuel pump without knowing...
Old Mar 13, 2025 | 12:33 PM
Please let us know what you find out.
Good luck!
Old Mar 13, 2025 | 07:01 PM
without starting the engine ,,turn the key on (no start) if u here the noise,,then open the
gas door remove the cap as u listen again as the pump only runs for 3 to 5 seconds (once the key is on
and the fuel has drained back do it again to be sure that is where the noise is coming from.
the e-vac blower located behind the drivers headlight( that big black thing) if it is going it will Howell..jim
Old May 5, 2025 | 07:33 AM
wlkDwlk's Avatar
It was the fuel pump! Thank you!!
Old May 5, 2025 | 11:15 AM
Thanks for the follow up. It helps future diagnostics.
JSK
Feb 9, 2021 01:51 PM
RedInterior
Jul 2, 2011 07:48 AM
eganders
Jun 1, 2009 06:32 PM
smokey847
Mar 3, 2009 04:12 PM
SteveB1
Nov 17, 2006 05:34 PM
