Spare tire
Old Apr 1, 2025 | 02:33 PM
Louisquat's Avatar
Default Spare tire
2005 crossfire convertible owner here, what’s the best idea for a spare tire? Fix a flat, tire plugs, or AAA is not a good answer. Has anyone picked themselves up a decent spare somewhere? Like maybe off of an SLK? Thanks
Old Apr 1, 2025 | 04:11 PM
Nelson G's Avatar
Default Re: Spare tire
I keep a tire plug kit in my car and a good pump. I have used it and it works for what I need. The sealant can work if the whole is not too big and you have to rotate the tire to evenly spread the product.
Old Apr 1, 2025 | 06:21 PM
Plug kits are the best !!!
The liquid tire sealant destroys the tire pressure sensor ( TPMS) and often will even harden in the tire making is very off balance.
Plus the sealant that came with the Crossfires is so past date it has hardened and cant even be used
Old Apr 1, 2025 | 08:33 PM
Louisquat's Avatar
yeah it was a blow out so tire sealer would have been of no use, there has to be a better way then a $300 donut on eBay
Old Apr 2, 2025 | 12:11 AM
A $400.00 tire at a decent tire shop? While your at it, a companion on the other side sized the same as the one being replaced. Good luck.
Old Apr 2, 2025 | 01:03 AM
I think the only other solution for a convertible might be "Run Flat" tires.
If you use a donut tire, you will have to make or get another set of lug bolts that are the proper length for that donut. Especially for the rear wheels. If the lug bolts are to long, they will destroy the emergency brakes.
Old Apr 2, 2025 | 05:19 PM
Wadsworth's Avatar
Years ago, I believe there was thread about using a specific MB doughnut tire. I cannot remember if it was for an SLK. You will have to search deep into threads on the forum. Of course, even a doughnut wheel will not fit in roadster trunk.
Old Apr 2, 2025 | 08:14 PM
dcskmail's Avatar
First always keep good tires on your car, even if you have a spare, you will still need to know how to use the jack and be able to break loose the lug bolts with the tire tool or a breaker bar. Before you take the tire off the car you might as well try fix it with a plug also make sure your air compressors works and know how to use it. I have drove my car for 7 years and with good tires never had a flat. Here's a good tubeless tire repair kit there are cheaper ones out there but not as easy to use :
Amazon Amazon
Irishmission1953
Mar 5, 2023 10:47 AM
goykgo
25
Apr 30, 2014 06:45 AM
Convertible girl
Sep 3, 2013 12:16 AM
danewby
Oct 6, 2008 09:51 AM
steve1173
Oct 23, 2007 10:25 PM
