Key Fob Question
Old May 24, 2025 | 09:01 PM
Brian P's Avatar
Default Key Fob Question
I noticed yesterday that neither Key Fob will lock or unlock the driver's door. I did notice that the signal lights inside both blink 3 times. I figure that it's something silly, but I couldn't find it in searches.
Thanks,
Brian
Old May 24, 2025 | 11:23 PM
Default Re: Key Fob Question
Thanks,
Brian
Hi Brian,
try this and see if it will re-sync the fobs.
John
Old May 25, 2025 | 12:16 AM
Brian P's Avatar
Hey John, I’ll give that try tomorrow. Any idea why two fobs would suddenly become unsynced?
Thank you,
Brian
Old May 26, 2025 | 01:09 AM
Thank you,
Brian
Did you have the car's battery disconnected recently?
Old May 26, 2025 | 01:42 AM
Brian P's Avatar
I had the car on a battery drip charger until last week. I’ve had a few times to drive her this week. Could that do it?
Old May 26, 2025 | 07:32 AM
zip439's Avatar
Is the problem just the driver's door ? What about the passenger door and the trunk/hatch?
Do you have coupe or roadster?
Old May 26, 2025 | 07:34 PM
Brian P's Avatar
I’m sorry, missed your post. The lights blink, but it won’t lock or unlock anything. This is a 2005 coupe.
Thanks,
Brian
Old May 26, 2025 | 07:57 PM
Brian P's Avatar
Okay, we tried the process in the video. The turn lights blinked three times and one red light came on for a second. When I pulled the key out at the end and pushed unlock the turn lights blinked. We got out of the car and tried the fob, but it still didn’t work. My wife tried it, in case I fat fingered it and got the same result. 🤷‍♂️
Old May 27, 2025 | 06:27 PM
zip439's Avatar
Brian P, There are a number of things that can cause the problem with your car.
1.Do your interior lights in the center of your car up near the mirror turn on when you open the door? They are on the same circuit as other devices that open/lock your doors. If the lights are not working your fuse 9 has probable blown and needs replacement.
2.If your siren doesn't sound when you push the panic button on the FOB you need to disconnect the siren It is located under the cowl at the base of the windshield.
3.In the rear of the car the air pump that activates to lock/unlock the doors and trunk is located on the right side below the carpet and the styrofoam. It often gets soaked in water and the corrosion prevents the locks from functioning.
So you see there are a number of things that could be wrong. Number 1 is easy to determine so do that first. If you have no joy there proceed to number 2 as a failed siren can present several problems and it needs to be replaced or left disconnected. You can drive the car just fine without the siren. I have been doing it for over a decade. NO PROBLEMS. number 3 is the biggest problem. If you scan the car you may get a diagnostic code that will head you in the right direction, but the scanner needs to be able to get into the factory codes. OBD II codes won't get you where you need to go. You can determine if there is water in the rear of the car by running a piece of paper down past the styrofoam or under the car there is a rubber plug that you can slice with a knife. That won't tell you if there is corrosion on the wires, but if there is water in that space you found your problem for sure. Good Luck
Carjones
Mar 1, 2025 08:12 PM
nickwe21.
38
Sep 12, 2022 12:07 PM
Rapp47
Jul 9, 2019 03:28 AM
Fildo Dog
Jul 6, 2015 05:20 PM
Marine05
South Forum
Feb 2, 2011 09:23 AM
