Blower motor running with key off/out?
Old Sep 27, 2025 | 08:01 PM
No704's Avatar
Default Blower motor running with key off/out?
I expect something is wet that doesn’t like that! Yesterday we got an unusual amount of rain. And I did drive in water deeper than I would like to. In Tempe AZ so rain on this scale is very unusual.
any way I went out to breakfast this am and when I went to take off the battery was low. Click, click, click.
got a jump start and let it idle for about 10 min battery is a 22/09 so I went to ORilies to get a new one. Alt and battery tested good, but I noticed the hvac blower comes on after the key is off. Everything functioning normally with engine running. Fan speeds work, ac works.
pulled the under hood #36 fuse for now. But that means no AC, that’s not going to be great for the next couple months.
im going to leave the fuse out for a few days and hopefully something dries out.
passenger foot well was soaked!
any suggestions please!
Old Sep 27, 2025 | 08:27 PM
No704's Avatar
Default Re: Blower motor running with key off/out?
While everything is soaked anyway, I treated the engine bay to a good soap cannon and pressure washing!
Old Sep 27, 2025 | 08:44 PM
No704's Avatar
I should probably just take it out for a good high speed run, but that’s not going to happen today.
Old Sep 27, 2025 | 10:41 PM
I suspect the cowl drains are clogged. Search how to remove the cowl cover and clean out the drains, especially on the passenger side. When clogged, the water will overflow into the blower motor area, then to your floor. Important to get that issue taken care of due to electronics under the floor carpet.
Old Sep 27, 2025 | 10:50 PM
No704's Avatar
that had certainly crossed my mind.
Old Sep 29, 2025 | 02:22 AM
Hi,
here's a post I did that shows how to remove the cowl to clean the drains. You might want to replace or remove the alarm siren while you're in there. LINK - Drain cleaning and alarm removal
You might also have a bad blower motor resistor. Here's a post on how to replace that: LINK - Blower motore resistor replacement
Old Sep 29, 2025 | 05:36 PM
No704's Avatar
Hi,
Blower motor speeds were all fine with the engine running. Still have the fuse out. I’ll let it dry out for a few days. Thx.
Old Oct 9, 2025 | 09:27 PM
No704's Avatar
Pulled the cowl cover this am, expecting rain all weekend. Drains were very clogged up with piles of leaves on top of them. Shop vac got the leaves. And I used compressed air with an additional length of 1/4” tube to blow thru. Amazing how much dirt was in them. Hopefully clear now. Wish me luck in the upcoming storm. Only found the end ones. Is there a middle one??
Old Oct 9, 2025 | 11:23 PM
Watch this video beginning at 11:25 all the way to the end to see all your cowl drains and one more under your battery
Old Oct 10, 2025 | 12:24 AM
There are two in the center. Both drain over the transmission.
LINK - Alarm removal/ replacement & Drain cleaning
Old Oct 14, 2025 | 07:50 PM
No704's Avatar
Guess I missed a couple! Got 1/2” rain in about 15 minutes. Got maybe 1/3 cup dripped on to pass floor board. Big improvement but I’ll go back in one of these days. Pretty easy to ignore in PHX.
XxfirexX
Aug 26, 2021 09:34 PM
DHS
Mar 31, 2021 07:01 PM
05srt6rebuild
Aug 27, 2018 07:41 PM
Lyn
24
Feb 22, 2018 04:07 PM
