Battery drain
Old Dec 27, 2025 | 07:29 PM
Denbob55's Avatar
Default Battery drain
Hi all. I could use some help on a battery drain. It had me stifled, so I took it to a shop that is excellent on electrical. He said I have a 1/2 amp draw on the antitheft system modules. He tried to find modules, but none are available.
Have any of you found a fix for this problem. If it is antitheft components, who has any, or is there a work around?
thanks
Old Dec 27, 2025 | 08:01 PM
Default Re: Battery drain
Generally, it comes down to the alarm under the wiper cowl. The batteries in the alarm leak causing damage to the circuit board. This will but a small drain on the electrical system of the car. If that is your issue, you can just disconnect the alarm. Finding new one is almost impossible. If you find one, make sure it is not an old one just never used. Aging is the issue. More info will follow.
You should have come here first!
James
Old Dec 28, 2025 | 09:24 AM
What James said.
Old Dec 28, 2025 | 11:57 AM
Wadsworth's Avatar
My Journey with my 2006 Roadster "Svengoolie
Check out this thread. Really good DIY instructions. The siren is in there.
Old Dec 28, 2025 | 12:40 PM
https://www.crossfireforum.org/forum...vengoolie.html
Old Dec 28, 2025 | 03:49 PM
Nelson G's Avatar
go here: https://www.crossfireforum.org/forum/585345-post1.html
Then look for: Finding Battery Drain V3 by Pizzaguy
Finding Battery Drain V1 by Pizzaguy
blacktouring
Aug 29, 2021 12:10 AM
angelomd
Dec 7, 2014 06:22 PM
sive81364
Feb 26, 2011 07:55 PM
joe lonardo
Jul 1, 2010 07:22 AM
buff5
Nov 12, 2008 04:27 PM
