ABS Pump Replacement
Old Jan 21, 2026 | 11:49 AM
Discourse's Avatar
Default ABS Pump Replacement
I recently bought a 2004 3.2 V6 Chrysler Crossfire and have been having a few issues. One of them is the speedometer not working and spoiler not going up or down. I've brought it to a mechanic and he's had a look. He says it's an issue with the pump, I need to get a new one.
Before buying I just want to make sure that this would be the right one for me to get? https://www.ebay.co.uk/itm/116930491742
Old Jan 21, 2026 | 01:37 PM
Default Re: ABS Pump Replacement
EVERY TIME this has come up, the issue was no power to the ABS module. THis is caused by a failure of the RCM (Relay Control Module).
GO order a relay control module for a 2003 Mercedes SLK320. (Or order one for a "Crossfire" if you like wasting time, just don't show up here crying you cant find one.) ANYWAY, the module plugs in without tools, you need no dull-witted "mechanic" for this. The RCM is in the BIG electronics box next to the battery. THe lid comes off without using tools and the RCM will unplug without tools, but DO NOT pull on the wires, grasp the CONNECTORS to unplug them.
You will be on the road in no time, unless you let that "Mechanic" "fix" the car.
(If is sounds like I have no respect for "mechanics", that is not really the case. It's just that I am disgusted with them for not learning even basic electrical concepts, given they work in a very electronic vocation.)
RCM is in the yellow circle:
Old Jan 21, 2026 | 01:48 PM
Old Jan 21, 2026 | 05:27 PM
Discourse's Avatar
Okay thanks for your help! Just to double check would this be what I'm looking for? https://www.ebay.co.uk/itm/227163010889
Sorry I'm not very handy!
Old Jan 21, 2026 | 05:52 PM
zip439's Avatar
Yes that is correct RCM, but it appears to be used. You need to get a new one as a used RCM may have the same or additional problems. Read the discription the seller gives.
Old Jan 21, 2026 | 06:09 PM
Discourse's Avatar
Hmm, I've had a look but can't find anywhere selling new in the UK
Old Jan 21, 2026 | 07:53 PM
I find that hard to believe, search "2003 Mercedes SLK320 Relay Control MOdule", the 2003 SLK230 version also works.
THe RCM has a very high failure rate, in the three Roadsers I've owned since 2009, two have failed. THey fail so much, we have a guy in Arizona who, for $65usd, replaces all relays and reflows the board. He has fixed several hundred since 2008.
I agree with Zip, buying used is not what I'd do. That one's board looks good - but they don't show a good photo of the relay contacts, which are paramount to the car running.
Old Jan 21, 2026 | 10:25 PM
@Discourse Hello, the Relay Control Module you are looking for is in the pictures below. Also Mercedes-Benz refers to it as K-40 Module.
You might be able to get one from amazon. Here's a link ignore the can't ship to warning, I'm in the U.S.A. but I switched to the U.K. Amazon.
LINK to RCM UK Amazon LINK to RCM UK Amazon
Old Jan 22, 2026 | 07:42 AM
Discourse's Avatar
Thanks so much for your help! I really appreciate that. I've bought a new ABS pump on the mechanic's recommendation - it's not too much money so not the end of the world if it wasn't totally necessary.
Unfortunately Amazon won't ship the RCM to me here in Northern Ireland Is this the same thing? https://www.ebay.co.uk/itm/165708594342
Thank you
Old Jan 22, 2026 | 09:15 AM
Yes
Old Jan 22, 2026 | 09:28 AM
Discourse's Avatar
Damn lol they won't post it either. Looks like no where will post it to the UK
Old Jan 22, 2026 | 10:09 AM
You could try reaching out to tighed1@hotmail.com and see if he will rebuild it for you? Even with postage, it might not be any more expensive than new.
Old Jan 22, 2026 | 12:19 PM
This may be your best bet. Transit time will stink, but I think the cost would be quite a bit lower, based on the prices you show in your posts.
Old Jan 22, 2026 | 02:16 PM
OUCH, those prices are outrageous! Rebuild or find something less expensive (don't buy used ones, they may be unserviceable)!
Old Jan 22, 2026 | 02:26 PM
They are even $200.00 on Amazon now; Tariffs are kicking our butts.
Old Feb 6, 2026 | 01:21 PM
GannyX's Avatar
I know Robert R (across the pond in the uk) travel to the states, I would ask if he could pick up one for you?
Old Feb 6, 2026 | 03:17 PM
Discourse's Avatar
Who is Robert R? But if it's easier to get one made like this, I would be all ears! Rreally want to get the car going
Dal
Oct 1, 2012 08:01 AM
rtmopar85
Oct 15, 2011 02:51 PM
TVT_DESIGN
Oct 15, 2009 10:30 AM
mrphotoman
Aug 31, 2008 10:46 PM
Chi-Town SRT/6
Nov 1, 2007 11:38 AM
