My Spoiler is staying up
Old Mar 14, 2026 | 05:40 PM
KWW's Avatar
KWW
Angry My Spoiler is staying up
I am wondering if someone can give me some advice please, I live in the UK and have a 2005 Roadster with 52K miles on the clock which I am currently experiencing problems with, my spoiler does not retract, about a week ago I was giving the car a run, everything was performing as expected, no warning lights on or buzzers sounding, I pushed the car up over the 60 mph and the spoiler was activated, but looking in my rear view mirror I could see the spoiler had not been fully deployed, and when I stopped the spoiler did not retracted, again there were no warning lights on, or buzzers sounding, so I pressed the spoiler switch and the little red light in the middle of the switch begun flashing and the spoiler remained up.
I will add that the car is kept on our drive all year round with three tarpaulins over it, I have since pulled everything out of the boot and that is bone dry, so I am pretty sure it is not water ingress that has caused the problem, I have also checked the fuse boxes and all fuses are OK, but while playing around with various switches I thought I would lower the roof, I released the catch and the side windows went down, but then it stopped its cycle, after playing around with the switches nothing happened, so I disconnected the battery for a few minutes and then re-connected it, but nothing happened, no change, so I then locked the roof, then pressed the window lift switches and the windows went up, I have since driven the car, it goes fine, but the fault is still there, can you help me I would appreciate you feed back?
Ken
Old Mar 15, 2026 | 12:33 AM
Default Re: My Spoiler is staying up
Ken
How old is your battery?
Sometimes when the battery starts to go bad weird things start to happen with the electronics. There should be a date code on your battery. If it's more than 3 years old you might want to change it or at least have it tested.
Old Mar 15, 2026 | 04:08 AM
KWW's Avatar
KWW
Hi Thanks for your response to my question, my original battery was replaced with a Varta 096 (77ah) battery in October 2017, while the battery is coming 9 years old I will add I am pretty sure the battery is still in good condition, the car always starts first time on the key, also I have a trickle charger on a timer wired up to the car battery to keep it topped up. Nevertheless I will have it tested.
Once again thanks for your comments
Ken
Old Mar 15, 2026 | 10:02 AM
The spoiler going up is an early warning of battery failure. At 9 years old you are overdue for a new one.
Old Mar 15, 2026 | 12:14 PM
In nearly 19 years on this forum and 19 years of owning 2 Crossfires I have never kept a battery older than 6 years installed in my Crossfire.
These cars are very reliant on proper voltage and a battery more then 6 years old isn't worth having under the hood.
I use battery tenders and maintain the charge as needed but that is still not a reason to expect a battery to last longer than 6 years.
Its the simplest thing to buy and install yourself to eliminate it as a problem for any other troubles you are experiencing
A spoiler not functioning properly has been known to be a result of a failing battery and I have seen this here many times over my many years here
Old Mar 15, 2026 | 06:13 PM
I would never run a battery for 9 years, especially in a Crossfire. It doesn't matter if it tests good, it will fail at any time.
Old Mar 15, 2026 | 11:51 PM
Like other members who chimed in here, I also suggest you replace the battery. Too many ppl have the battery tested good but the moment they replace the old (supposidly good) battery their problem is SOLVED. Good luck!
jeromecurrier
May 13, 2024 10:23 AM
nickwe21
Dec 5, 2021 12:29 PM
Sixkay
18
Sep 21, 2021 12:20 PM
Reliableron
Oct 17, 2015 10:19 PM
Freezer
Sep 13, 2014 12:55 PM
