Belt Tensioner replacement
Old May 3, 2026 | 09:48 AM
UrbanE's Avatar
Default Re: Belt Tensioner replacement
My understanding is the 17 mm “nut” on the face of the NA tensioner gets in the way of the belt
This is why the SRT tensioner doesn’t have that “nut” on the face of the tensioner. The tensioner is released via the pulley bolt stem. The bolt holds the pulley and both the bolt and pulley are different
on the NA you can remove the bolt, on the SRT you cannot remove the bolt stem, the pulley is held in place with a nut on the pulley bolt stem.
if the SRT tensioner bolt stem is loose, the pulley is toast. There is no way to tighten the bolt stem
the tensioners shown on rockauto and autohaus are for the NA
The tensioner listed will not work on the SC Engine.
Old May 3, 2026 | 09:53 AM
UrbanE's Avatar
this is what the tensioner for the SC Engine looks like.
Old May 3, 2026 | 10:06 AM
UrbanE's Avatar
This is the tensioner for the NA
They are different
I have a spare for the M112K but I’m like every owner of this engine, I would like to access a longer term solution
Old May 3, 2026 | 09:15 PM
Thanks GraphiteGhost and UrbanE for the pics and explanations. The problem with the bolt on the SC is that the end where you attach the socket can get distorted.
I've seen this in person. I was helping another member install a pulley saver kit on their SRT6 and we had a hell of a time getting the belt back on.
The previous owner must have used the wrong sized socket or something. Or they didn't re-seat the socket when it started slipping.
Old May 6, 2026 | 03:30 PM
One more question, if the bearings in the pulley go bad can you still replace the pully? Are they available?
Old May 6, 2026 | 05:23 PM
NeedsWings's Avatar
yes we can still get the pulleys
Old May 6, 2026 | 07:31 PM
Yay! For everyone with an SRT-6 with a stock motor! LOL
Old May 6, 2026 | 10:54 PM
nickwe21's Avatar
I could have sworn I saw an SRT for sale somewhere bring a trailer) and it had the N/A tensioner pulley, but as always I could be entirely wrong. Everything that has been said, makes much more sense
Does anyone know how to replace the bearing in the tensioner pulley?
Old May 7, 2026 | 08:56 AM
NeedsWings's Avatar
this is the same pulley as the one used on the srt6 tensioner
https://www.needswings.com/large-idler-pulley-m112k
Old May 7, 2026 | 05:02 PM
nickwe21's Avatar
How would one go about removing the one from the tensioner and replacing with this one?
Old May 7, 2026 | 05:30 PM
NeedsWings's Avatar
remove belt e10 torx, remove 15mm nut holding pulley on, swap pulleys, torque nut to 15 ft/lbs, reinstall belt
X-fired
Mar 25, 2023 03:53 PM
fyrepower
Jan 28, 2018 06:56 AM
MikeR
Dec 2, 2012 01:47 PM
kolevski
Mar 15, 2010 09:01 AM
