Vaccum pump
Old Mar 27, 2026 | 09:45 AM
richb55's Avatar
Default Vaccum pump
My vaccum pump seems to run all the time draining the battery. Is it just old ?
Old Mar 27, 2026 | 10:54 AM
Default Re: Vaccum pump
For the engine or for the door locks?
Old Mar 27, 2026 | 11:48 PM
Do you mean the central locking pump? The one that's located in the trunk on the left side?
Check to see if there was any water damage. Disconnect the wire harness and see if there is corrosion on the pins.
Old Mar 28, 2026 | 06:17 PM
richb55's Avatar
I should have said air pump for locks , seems to run and kill battery. Any thoughts outside of replacement
Old Mar 29, 2026 | 01:24 AM
In the engine fuse box, try pulling fuses #25 and #26. See if the pump stops.
Old Mar 29, 2026 | 09:43 AM
Do a search of Central Locking Pump in the upper L/H corner of thit sight and you will get all kinds of info. Do you have a roadster or coupe? Removing t for inspection is the first step.
Old Mar 29, 2026 | 10:42 AM
richb55's Avatar
yes thatwould be the culprit it’s 2005 coupe.
I used to think it was fuel pump building up pressure
Old Mar 29, 2026 | 11:10 AM
You can get one off E-bay but be sure to get the wires and connectors with it.
VaderMarine
Oct 17, 2023 12:01 PM
Dal
Oct 1, 2012 08:01 AM
RED DOG
20
Jul 26, 2012 05:45 PM
TVT_DESIGN
Oct 15, 2009 10:30 AM
mrphotoman
Aug 31, 2008 10:46 PM
