Strange Noise From Rear?
Old Jan 11, 2008 | 10:50 PM
addie18's Avatar
Exclamation Strange Noise From Rear?
I test drove a crossfire today, that I hope to buy, and there was an odd whining noise coming from the rear. I was just wondering if anyone has expierienced this? It only happens when you rest your foot against the gas pedal. Thank you for any advice/input!
Old Jan 11, 2008 | 11:03 PM
sonoronos's Avatar
Default Re: Strange Noise From Rear?
Can you please explain the phrase "resting your foot against the pedal" more clearly?
Are you trying to convey to us that the whining noise happens when you are accelerating?
Old Jan 12, 2008 | 04:35 AM
Chris L.'s Avatar
Sometimes when my wife is in the car....I hear an odd whining sound when I put the gas pedal all the way to the floor?
Old Jan 12, 2008 | 11:24 AM
addie18's Avatar
I was neither accelerating nor had my foot off the pedal. It happened while I was maintaining speed.
Old Jan 12, 2008 | 11:44 AM
Shawnkey's Avatar
It is the rear differential teeth mateing, since it's not at a load, but not dec elerating, you do get some noise. If it is real loud, and gets louder with raises in speed, there might be a problem. If you buy make sure there is a transferable powertrain warranty, that will cover it for 7 years 70k miles.
Shawn
Old Jan 12, 2008 | 12:34 PM
Shawnkey's Avatar
I though I had already replied to this post once before, There only needs to be one post made in the appropriate sub-forum
Old Jan 12, 2008 | 02:06 PM
SRT-6 Steve's Avatar
That's funny. Does it stop when you leave off the gas?
Steve
Old Jan 12, 2008 | 02:09 PM
Mine does this around 62 - 63 MPH then goes away over or below this speed. Not sure why. Probably just a certain harmonic issue when things are just right. Don't think mine is an issue. It that the speed you noticed it?
Steve
Old Jan 12, 2008 | 02:36 PM
addie18's Avatar
Sorry about posting the question in two places. I origionally didn't realize that there was a mechanical forum. Thank you all for the answers. I was told that the 7/70,00 powertrain warranty is transferable to the 2nd owner and it is a one owner car.
Old Jan 12, 2008 | 04:36 PM
Fenwick223's Avatar
You definitely want it covered by the warranty because the repair is $3,300 - $3,500.
Old Jan 13, 2008 | 12:23 AM
alfdoc's Avatar
Question Re: Strange Noise From Rear?
I know this my sound stupid but, Did you happen to see if the wing was deploying {55 to 65 MPH depending on the car} at the time? I have had to disassemble mine and lube the actuator and linkage because it started to get a very loud wine to it. Also after i lubed it, i could hardy hear it deploy or stow it self.
Old Jan 15, 2008 | 10:28 PM
addie18's Avatar
Talking Re: Strange Noise From Rear?
I bought the car and got the warranty changed intomy name today. So thank you for all the info everyone.
Old Jan 16, 2008 | 05:33 PM
DrMike's Avatar
I have same problem, couldn't find a recall for problem
Old Jan 16, 2008 | 06:49 PM
Maxwell's Avatar
I have heard this noise too, but it only occurs on this one street near my house, no other time do I hear the whine. Also my tires are down to the wear bars. I just find it strange that it only happens on this one street I take to go to work,
Old Jan 16, 2008 | 11:58 PM
CALL911's Avatar
Shawn
I agree, Mine does the same thing. The reason you can hear it is because the rear diff. is right behind the bulk head and there is no separation between the passenger compartment and the trunk area. I would suspect that almost all rear diffs. make this noise, you just don't hear it because in most vehicles the rear diff. is separated by the trunk .
Old Jan 17, 2008 | 05:09 AM
Stogey's Avatar
All differenials make a whining noise, because our butts are almost sittin on the top of the Crossfires diff and we have this big sound amplifying space behind the bulk head is why I suspect the whine is so prevalent in our cars.
Has anyone considered swapping to a synthetic lube such as Redline High Shock in their differenials ?
Old Jan 17, 2008 | 02:57 PM
Maxwell's Avatar
yeah your probably right it's normal, since it's bolted to the cars chassis, that also transmits a droaning sound from the gears.
usprb1976
Apr 4, 2024 04:57 PM
Jonacross
20
Jul 17, 2017 11:19 PM
nataliefs
Oct 5, 2015 01:03 PM
cppeabody
Sep 15, 2015 08:43 AM
xjken
Sep 13, 2015 10:18 PM
