Do you want a Keyless Entry Alert Tone?
Old Nov 9, 2008 | 01:37 PM
  #101 (permalink)
crookedview's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
Excellent write-up. Used the 059 buzzer on my '04 Crossfire.
Mounted it inside the fuse box and it's easy enough to hear as long as there's not a lot of surrounding noise.
Thanks!
Old Nov 10, 2008 | 07:25 AM
  #102 (permalink)
teb5's Avatar
Got my crossfire a couple of weeks ago and stumbled across the forum. Tons of great info. I don't know a ton about electrical stuff, but was able to follow the instructions in this tread pretty easily. The problem is my chime is very faint. I got the -060 chime from RS and mounted it outside the fuse box. I can barely hear it even when standing right next to the car. Any hints? TIA.
Old Dec 17, 2008 | 09:04 AM
  #103 (permalink)
drivethruecp's Avatar
What if you wired to the factory siren (under the cowl) rather than a buzzer to the relay?... Anyone try it or ha e an idea of what it would sound like?
Old Dec 17, 2008 | 10:10 AM
  #104 (permalink)
corfire's Avatar
That wouldn't get you a keyless entry sound. It would only add (not much) to the sound of the alarm going off if you have the original factory siren. If you replace the factory siren with a new updated version, you will more than likely get a keyless tone/chirp sound when locking and unlocking. However, it is much cheaper and easier (I think) to do the Radio Shack tone-buzzer mod given at the start of this thread with about the same results! If you want to increase the sound, just buy a more powerful Radio Shack tone buzzer (higher dB's).
Many on the Forum have had a defective factory siren replaced under warranty and ended up with a keyless chirp as an end result. Some have replaced the siren on their own. You can do a search for part numbers. Apparently, the original sirens didn’t provide that function, but the new off the shelf version does?
Old Dec 17, 2008 | 10:58 AM
  #105 (permalink)
Thanks for that response!!! Well put. Can anyone else confirm that the newer buzzer adds this function for everyone that replaced it? Mine is an 07 ltd.
Old Dec 29, 2008 | 08:46 PM
  #106 (permalink)
elmanb91's Avatar
Smile Re: Do you want a Keyless Entry Alert Tone?
Here’s how I got a tone sound when locking and unlocking the Crossfire with the key fob remote for less than $5 and a just a little bit of work!
The short version is that you install a 12 VDC low current ‘tone’ buzzer across the coil of the Remote Keyless Entry Relay. This is the relay that blinks the front & rear signal lights 1 time when the doors are unlocked and 3 times when locked by the remote. The buzzer needs to be installed in parallel with the relay coil, not the relay contacts. If installed across the contacts, it would make noise anytime the lights are on! Not what we want!
Figure 1 attachment is a wiring diagram of the ‘Tone’ Buzzer installation.
I used a Radio Shack Piezo Buzzer (P/N 273-059, Picture 1 attached). It is a very small and gives off a not so loud 2700 Hz tone that is audible, but not obnoxious, and it only consumes 10ma of current (.010 amps). Radio shack has a wide variety this type of buzzer. They give off various sounds at various volumes depending on which one is used. I also, tried a 273-060. It was louder than I wanted and a bit higher in frequency but is also a good choice. Here’s a link to the Radio Shack stuff:
http://www.radioshack.com/family/index.jsp?categoryId=2032266&cp=2032058.2032230
I picked one of the cheap ones at the bottom of the list. It needs to be capable of operating at 12 VDC. I recommend a low current type. Say 50ma or less, just because that’s all I tried, and it will be installed in parallel with the relay coil, not the contacts. Anyway, you could experiment with different sounds to get what you want. I just found that the little cheap one met my needs. See the next post (after SVO's Reply )for more about the installation with more pictures and diagrams.
wow just what i wanted. thanks a bunch!
Old Dec 30, 2008 | 10:52 AM
  #107 (permalink)
nate_man's Avatar
OK everyone here is the official sound clip from the radio shack device
Turn up your sound.....
http://www.youtube.com/watch?v=URCocPE2Mpg
V,
THanks for the vid. BTW what was the number on the device that you purchased from RS. I think that yours has just the right volume.
Thnx'
Nate
Old Feb 9, 2009 | 07:03 PM
  #108 (permalink)
nate_man's Avatar
Corfire, Just wanted to say thanks for offering this up and yes I just did mine and voila. It worked like a charm!
THanks again for posting this!
Nate
Old Feb 9, 2009 | 10:01 PM
  #109 (permalink)
corfire's Avatar
Thumbs up Re: Do you want a Keyless Entry Alert Tone?
Nate
Your very welcome. It appears that it's been awhile since anyone has tried this simple little mod. Which tone buzzer did you use?
Old Feb 10, 2009 | 07:43 AM
  #110 (permalink)
nate_man's Avatar
You know I cannot remember but I think that I went with the 60 but it could be the 59. I had to locate it outside of the fuse box because it was silent with the hood down. The great sealing of the hood hides a lot of the sound on these
Thanks
Nate
Old Feb 13, 2009 | 02:13 PM
  #111 (permalink)
rick-eureka's Avatar
OK I presum;e you are talking abouthe Trail of The Dragon run. I did it on my Harley. Is tehre a special date or event for XF folk?
Rick
Old Feb 20, 2009 | 01:02 PM
  #112 (permalink)
cisa's Avatar
Thanks Corfire,
Going to do the "Alert Tone" this weekend. Plan to attach it outside the cover with Velcro. Great job with the attachments. If anyone can't follow what you did they need to be taken off life support. Just got my Crossfire last Friday in Ft. Myers. I love it!!
Having this forum is GREAT.
Old Feb 20, 2009 | 02:57 PM
  #113 (permalink)
Jerry476's Avatar
I added the buzzer and it works great.
Just got a 2004 and love both it and the information in this forum!
Old Feb 21, 2009 | 04:41 PM
  #114 (permalink)
Erzer's Avatar
While it does work, I noticed that when it got cold, it became intermittent and then stopped working all together. I reset the fuse and it reset for about a half day but is once again not working reliably. May have to add some stronger wire and maybe better protection for the "buzzer".
Old Feb 21, 2009 | 08:39 PM
  #115 (permalink)
corfire's Avatar
I am guessing that you probably have loose connection.
Old Mar 4, 2009 | 01:29 PM
  #116 (permalink)
smokey847's Avatar
Ok. Stupid AMETEUR question...
Where would be the best place to buy small gage solid wire? Thanks.
Old Mar 4, 2009 | 04:51 PM
  #117 (permalink)
cisa's Avatar
Best Place?
Same place as the buzzer, Radio Shack.
My project this weekend will be puttig in the capacitors on the Mid Range speakers to push the bass to the rear (behind seat) speakers. Another great forum idea!!!!
Also thinking about a murcury switch controlled light for under the hood. Anyone with an Idea?
Old Mar 8, 2009 | 09:56 PM
  #118 (permalink)
nate_man's Avatar
Got mine at Home Depot .25 and that was it for a foot!
Hope you get it done it is the perfect mod!
Old Mar 21, 2009 | 01:35 AM
  #119 (permalink)
viper065's Avatar
Corfire -
I just want to say thank you for the information. I did this simple install last weekend and took me all of 5 minutes to do! I went with the 273-060 sounds great! Thanks again
Justin
Old Mar 21, 2009 | 12:16 PM
  #120 (permalink)
corfire's Avatar
Originally Posted by viper065
Corfire -
Justin
Your welcome! When I think that my simple mod has died an gone to heaven, someone runs into it on here and finds it useful. Most have used the 273-060 because it is a little louder.
