Do you want a Keyless Entry Alert Tone?
Old Aug 14, 2008 | 07:15 PM
  #81 (permalink)
corfire's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by donedharm
Just put mine in today LOVE IT I'am still smiling It was so easy,only took about 10 min.Thanks for the information
I think that it is surely easier and less expensive than spending about $100 on a new siren and tools, and removing the wipers and cowling to replace it. However, that is the other way to do it, and some have with success. Enjoy the new sound!
Old Aug 14, 2008 | 07:19 PM
  #82 (permalink)
donedharm's Avatar
I will,and Thanks again Corfire
Old Aug 19, 2008 | 08:04 AM
  #83 (permalink)
xfirepop's Avatar
Corfire, you're a genius. Thanks for the info. It works like a charm. Five minutes and I've got tone!!
Old Aug 19, 2008 | 07:06 PM
  #84 (permalink)
roncosrt6's Avatar
Corfire, thanks a million. Easy and loud enough.
I just hate to solder.
Old Aug 23, 2008 | 05:52 PM
  #85 (permalink)
brucero's Avatar
CORFIRE,
Thanks for the information. I returned from the local radio shack, and voila!
The fuse layout on my 07 coupe is different...
There are no relays at all in this box..
Has onyone done this with a later model Crossfire?
Bruce
Old Aug 23, 2008 | 10:41 PM
  #86 (permalink)
corfire's Avatar
Unhappy Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by brucero
CORFIRE,
Bruce
I don't know if an 07 is different. I'm am wondering if you just opened the fuse box lid. On my 04 you must remove the whole top cover (that includes the lid) to expose the relay. Just wondering? If there is a relay in another location, you should be able to find it by listening for it 'clicking' when your lights blink when you operate the door locks with the remote.
Old Aug 24, 2008 | 06:45 PM
  #87 (permalink)
brucero's Avatar
CORFIRE,
You were correct, I didn't catch that there was another lid under the fuse opening...
Found it by listening to the relay clicking...
Reading back, it is well explained, but I missed it.
I used the RS, 273-066 larget buzzer. Currently it is installed under the fuse box, but I might put it outside in order for it to be louder.
Again, thank you for your assistance. I appreciate your patience and help.
Bruce
Old Aug 24, 2008 | 09:09 PM
  #88 (permalink)
brucero's Avatar
As an afterthought, if you mount the beeper outside of the fusebox, do you need to weather proff it?
and if so, how?
Bruce
Old Aug 25, 2008 | 08:58 AM
  #89 (permalink)
corfire's Avatar
and if so, how?
Bruce
Mine is mounted right outside of the fuse box with the wire run along side of one of the rubber plugs. It doesn't seem to get wet and hasn't failed yet. If it fails, another 3 dollar buzzer will fix it, and then I'll worry about protecting it better.
By the way, your not far from me in Spokane, WA.
Old Sep 14, 2008 | 06:58 PM
  #90 (permalink)
tcar32909's Avatar
I took my crossfire to the dealer with a bad siren on the alarm, it would just make a lil gurgling sound, not a loud alarm siren sound. So they replaced the siren. And now when i lock and unlock with the key fob, i get a nice lil beep to confirm lock and unlock. Dont know if this is new or what, just was happy that I now can hear that it is locked.
Old Sep 21, 2008 | 07:06 AM
  #91 (permalink)
SNAKEWOLF's Avatar
Cool Re: Do you want a Keyless Entry Alert Tone?
TOOK 3 MINUTES AND IS OK JUST ENOUGH TO HERE AT CAR AND NOT THE PARKING LOT BRAVO FOR SOMETHING ANYONE CAN DO JUST LOOK AT THE PITCHURE FOR SURE A STICKY
Old Oct 24, 2008 | 07:18 AM
  #92 (permalink)
tighed1's Avatar
Ok its been a month since the last entry so I'll bring this back for those that haven't seen it yet.
Bought the 060 and installed it. Piece of cake. even went so far as to open the relay and pretty up the wiring like JAMES1549 did (thread #65)
Mounted the buzzer outside of the fuse box onto the side of the inner fender using silicone. Works like a champ!
Old Oct 24, 2008 | 08:13 AM
  #93 (permalink)
jackei's Avatar
and if so, how?
Bruce
You don't need to worry too much about the beeper getting wet, unless you always wash the engine bay. I actually put the beeper inside a tiny plastic bag, then seal the opening with the wire going through, works good and inexpensive.
Old Nov 3, 2008 | 12:31 PM
  #94 (permalink)
ShirazRoadster's Avatar
Did a slightly ghetto install in about 10 minutes! Sadly our Radio Shack charges $4.49 for the buzzer, but it works perfectly. I have my buzzer inside the fuze box, plenty loud for me. Thanks soooo much for this idea!
Old Nov 5, 2008 | 06:35 PM
  #95 (permalink)
SRT6LVR's Avatar
This was a piece of cake. A child could've done it thanks to the great instructions! Thanks!
Old Nov 6, 2008 | 05:58 PM
  #96 (permalink)
green-ghost's Avatar
this is perfect! I used the 060 and hooked it up in about 30 minutes, measure twice cut once . I did end up mounting the buzzer to the fender and not inside the box. oh and if you decide to mount it to the outside of the fuse box; be sure not tot mount it right where the lid snaps itself closed...doote!
Old Nov 6, 2008 | 06:17 PM
  #97 (permalink)
corfire's Avatar
Thumbs up Re: Do you want a Keyless Entry Alert Tone?
Glad to see that there is new interest in this simple, cheap and easy mod. Enjoy!
Old Nov 7, 2008 | 07:37 PM
  #98 (permalink)
Skyshadow's Avatar
OK, I picked up one of these buzzers at Radio Shack today and just spent the last 20 minutes or so installing it. That time included gathering up everything I needed and putting everything away when I was done. I mounted the buzzer outside the fuse box with some double sided 3M tape, securing it to the adjacent body panel.
I really like how it isn't terribly loud and annoying, just enough to confirm that the doors are locked/unlocked. Once again a big THANK YOU to corfire for the how-to on this!
I know this is a old thread but I'm new here and i was wondering if you were able to get the buzzer on the outside and still have a good seal on your fuze box?
Old Nov 8, 2008 | 11:11 AM
  #99 (permalink)
Mike-in-Orange's Avatar
Yes, the fuse box cover closes fully. I'd have to take a look at it again but I recall there being a convenient little slot or something that the wires fit through nicely. I'll take a look a little later and report back for you.
Old Nov 8, 2008 | 09:07 PM
  #100 (permalink)
tighed1's Avatar
I cut a small slot just enough to pass the two wires through then siliconed the slot. Perfectly sealed box.
