Do you want a Keyless Entry Alert Tone?
Old Apr 18, 2008 | 07:04 PM
  #61 (permalink)
jackei's Avatar
Default Re: Do you want a Keyless Entry Alert Tone?
Yep I also installed the 273-060 buzzer, and I moved it outside the fuse box. I can hear nothing when the buzzer sit inside the fuse box in a noisy environment, now it works perfect. Attached a picture how I connect the wire to the outside of the fuse box, I think this is the best way to do it, going through one of the rubber outlet so no chance for the water to get in the fuse box (the white wire)
Old Apr 28, 2008 | 02:01 PM
  #62 (permalink)
P-DuBBs's Avatar
i just bought my Xfire recently and noticed that there was no sound when I locked the car....made me nervous and I kept double checking to make sure it was locked (I'm sure my FOB battery would be dead within a matter of weeks).
Anyway I bought the buzzer at radio shack and followed the posted instructions (really easy...works great).
I left the buzzer hanging outside of the cover because the tone was really really weak otherwise.
Thanks much....I'm still learning my car.
Look at Picture 3 as originally posted by corfire - you see where he has the buzzer mounted inside the fuse box? Well, right next to it there is a bit of a slit that matches up with the clip that secures the lid. I just laid the wires into that slit and, using a bit of 3M double sided tape, stuck the buzzer to the inner body panel adjacent to the fuse box. The lid still snapped into place as before the install.
I agree with Mike...I did the same thing when I was trying to figure out the best way to route the buzzer outside of the fuse box.
Old Jun 17, 2008 | 06:12 AM
  #63 (permalink)
MUTT's Avatar
a little late on this post, but i just ran a wire from the #87 pin (see diagram in the first post of this thread) directly to my horn. now horns beeps along with the lights when arming/disarming.
Old Jun 17, 2008 | 09:12 AM
  #64 (permalink)
corfire's Avatar
Yes, that certainly is an option, if you want a horn honk. You are then using the relay contacts to operate the horn, instead of the voltage across the relay coil to make the tone buzzer sound. I suggest that you make a very good connection (solder or crimp), because the horn will require much more current (several amps instead of just milliamps). Just wrapping the wire for the horn, as I did for the low current buzzer might (probably will) create a high resistance connection resulting in heat at that connection. That was and is one of my concerns about operating the horn with the keyless entry relay. Making a connection to the wire running to the receptacle for #87 would be the best way to connect if you can find it under the fuse box. Working with the higher current devices requires very good electrical connections.
Old Jun 17, 2008 | 07:28 PM
  #65 (permalink)
I did the install today. Thanks for the information! I went with the 059 buzzer, but may go back to get the 060. It is on the quiet side with the hood down.
I took a spare relay, opened it and soldiered the wires directly to the coil hook up.
Thanks again, James
Old Jun 17, 2008 | 10:28 PM
  #66 (permalink)
corfire's Avatar
Thumbs up Re: Do you want a Keyless Entry Alert Tone?
I agree that the 060 is a better choice than the 059. I will probably change mine sometime as I have a bit of trouble hearing the 059 in a noisy parking lot. I'm impressed with the way you made connection to a relay. You could actually solder to the pins on the bottom. However, the way you did it is very professional looking.
Old Jun 18, 2008 | 10:48 PM
  #67 (permalink)
Nexxus's Avatar
I did it! WOW! Nice mod. Cheap too. I know that you can change out the main horn and get the same effect, but the buzzer is so different it really sounds better. Thanks for the info to do this mod!
Old Jun 19, 2008 | 06:33 AM
  #68 (permalink)
MUTT's Avatar
DO NOT HOOK UP TO PIN #87
I NORMALLY DONT USE MY TURN SIGNALS AT ALL- AFTER HOOKING UP TO PIN #87 FOR 2 WEEKS NOW, THIS MORNING A COP WAS BEHIND ME SO I USED MY LEFT TURN SIGNAL. HORN GOES OFF EVERY TIME THE SIGNAL BLINKS...SORRY FOR THE BAD INFO
Old Jun 19, 2008 | 07:02 PM
  #69 (permalink)
JHTJ's Avatar
I NORMALLY DONT USE MY TURN SIGNALS AT ALL- AFTER HOOKING UP TO PIN #87 FOR 2 WEEKS NOW, THIS MORNING A COP WAS BEHIND ME SO I USED MY LEFT TURN SIGNAL. HORN GOES OFF EVERY TIME TH...E SIGNAL BLINKS...SORRY FOR THE BAD INFO
Haha, hilarious. Would have loved to see your face in the rearview on that one...
Old Jun 22, 2008 | 10:50 AM
  #70 (permalink)
wallycrossfire's Avatar
Cool Re: Do you want a Keyless Entry Alert Tone?
Sup Bitches
So I installed the keyless beep. Installed the 60
In Canada you can phone some Source by Circuit City
stores, cause some of them have old Radio Shack stock
on hand. There is quite a few in London.
Anyhoo, here is a link to the noise that it makes.
If someone already posted a link then now you have
2. Anyway, I love hearing beeps now. I hated every car
that I ever owned that used the horn, cause I am a shift worker.
Nothing like hearing car horns beeping at 4:00am.
Under the pretty blue circles with checkmarks in them click on FREE
You will have to wait a few seconds. Be patient.
The reward of learning patience is patience.
Then click on CLICK HERE TO DOWNLOAD
If you can't figure this out, please go watch a vhs copy
of goonies. Program the time on the VCR first, then come back
here and try again.
PEACE.
Wally - OUT
http://www.MegaShare.com/434490
Old Jun 22, 2008 | 01:18 PM
  #71 (permalink)
I switched over to 060 today. Much better. James
Old Jun 22, 2008 | 07:47 PM
  #72 (permalink)
BLKFIN's Avatar
ADDICTED TO BOOST
Now that is pretty funny. I bet you about crapped yourself when the horn started honking for no reason!
Old Jun 24, 2008 | 05:33 PM
  #73 (permalink)
bmerca's Avatar
outstanding find, thanks for this.
Old Jun 28, 2008 | 06:51 PM
  #74 (permalink)
ppro's Avatar
Default A Little Change...
I liked this but wanted to be able to turn off the buzzer anytime I want. And I wanted the buzzer to be protected from moisture but not inside the fuse panel. So I made a little project enclosure with the buzzer, switch, and for diagnostic purposes, an indicator lamp.
I borrowed a couple pictures from this thread - let me know if it's a problem and I will replace them with my own.
Click for Write-up
Old Jul 17, 2008 | 06:29 PM
  #75 (permalink)
OK everyone here is the official sound clip from the radio shack device
Turn up your sound.....
http://www.youtube.com/watch?v=URCocPE2Mpg
Old Jul 17, 2008 | 06:40 PM
  #76 (permalink)
Great video... sounds just like mine. James
Old Jul 18, 2008 | 09:08 AM
  #77 (permalink)
huudoo's Avatar
cool seems to be some work though i just listen for the click in the hatch
Old Jul 18, 2008 | 11:44 PM
  #78 (permalink)
manisusmc's Avatar
well i installed this mod today and i should have listened and pulled fuse 35, i blew it not paying attention, went to unlock the dorr to get out my spare fuses out of the glovebox alarm went off. that'll teach me to listen to people
Old Jul 23, 2008 | 09:33 AM
  #79 (permalink)
GassGhost's Avatar
Talking Re: Do you want a Keyless Entry Alert Tone?
PERFECT! 10 minutes to install including soldering, shrink tubing and installation. All for under five bucks. It's a perfect and simple solution to an annoying problem without having to spend a lot of money on a new siren.
Thanks for the great post and crystal clear installation instructions. Perfect beep to let you know the car is locking with out having to look at the headlights!
I mounted mine under the cowl just above the fuse box to protect it a little form car wash over spray.
Thanks!!!!!!!!!!!!!!
GassGhost
Old Aug 14, 2008 | 06:54 PM
  #80 (permalink)
donedharm's Avatar
Just put mine in today LOVE IT I'am still smiling It was so easy,only took about 10 min.Thanks for the information
