I need BIG help
Old Mar 25, 2009 | 02:03 PM
TaReGt's Avatar
Default Re: I need BIG help
Originally Posted by stryfox
Do you have a sprint booster installed? I had a similar problem with one of the early units. I got a new one and never had the problem again.
No....i might buy one
Old Mar 25, 2009 | 02:39 PM
waldig's Avatar
Talking Re: I need BIG help
WOOOOAH WOOOAHH hOLD ON HOSS!
Changing the fuel filter is not cheap. It is not easy and Id say not it.
1. Fuel filter is the fuel pressure regulator , that I have been all over and into. Photo attached.
2. YOu have a port to check the fuel pressure on the top of the engine, uses an AIR CONDITIONING GAUGE HOSE FOR HOUSEHOLD R22 FREON. NOT NOT R134A STYLE.
3. Borrow a gauge and check the pressure, s/b about 55 - 60 and not change under load. See how it did it.
It could be a fuel pump but I suspect it is neither part, get the code and save your buns and $$$$$
Enjoy Woody
Old Mar 25, 2009 | 05:29 PM
Iamfink2's Avatar
I had the same problem with my crossfire after installing a sprint booster then replaced it with a new one from the supplier. That being said are you the oringinal owner of the car, if not you could have a sprint booster and not even know it. I'm starting to have the same problems again but this time I'm going to remove it and leave it off. No more problems.
Old Mar 25, 2009 | 06:10 PM
TaReGt's Avatar
How to check for sprint booster? I mean guy before me was 50+ so i don't think so
And fuel filter is 300 to be changed They have to take fuel tank off
Old Mar 25, 2009 | 08:32 PM
Iamfink2's Avatar
Go to this link https://www.crossfireforum.org/forum...OOSTER+INSTALL then go to post #5 it will show you the installation procedure from there once you remove the gas pedal you should be able to figure out if you have a sprint booster or not and age doesn't have anything to do with it I'm almost 52 and I have one.
Old Mar 26, 2009 | 12:50 AM
TaReGt's Avatar
Thank you.
Please, i did not mean anything bad by 50+ ...
I apologize.
What fuel cleaner should i use?
Old Mar 26, 2009 | 07:10 AM
Iamfink2's Avatar
I apologize.
No need to apologize, no offense taken.
Old Apr 15, 2009 | 10:30 PM
TaReGt's Avatar
I got codes
P0730 Incorrect Gear Ratio
and ...
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
One of those 4, i cant remember which one.
So i will call chrysler tomorrow to fix that. Good thing i have max care
Old Apr 16, 2009 | 02:14 PM
Hands's Avatar
Probably. BUT, with a "Check Engine" light, you should really check to see what the DTC (Diagnostic Trouble Code) is first, before you do anything else.
That's what it's for.
Thats the answer max ...check it first,,,,,
Kodebuster
Nov 5, 2020 04:06 PM
Mackel
Oct 16, 2015 09:03 AM
velociabstract
16
Oct 12, 2015 10:56 PM
dbooso
Aug 27, 2015 11:03 AM
waldig
Aug 14, 2015 01:02 PM
