new ditch
Old Jul 28, 2009 | 12:30 AM
#52's Avatar
#52
Smile new ditch
hey i am the crossfire destroey but i love my car any ways after replacing my clutch total assemlyh i found that our side detent cable has 18 different detents per 2 to find all gears heel toe drivers u can shorten shift ratio in car
Old Jul 29, 2009 | 12:11 AM
newCrossfire's Avatar
Default Re: new ditch
______explain?
Old Jul 29, 2009 | 05:26 AM
Mimi05SRT6's Avatar
Originally Posted by newCrossfire
______explain?
I second that!
Old Jul 29, 2009 | 06:55 AM
apkano's Avatar
Life is random...so am I.
I believe what he's trying to say is......
Where the pedal actuates into the clutch mechanism, there's a number of detents spaced out along it's range. This allows you to adjust the pedal travel. Some people like their clutch to work very early in it's travel, wheras others might like the clutch to not work till it's near the end of it's travel. Basically it's just a way to adjust the pedal "feel" and the height at which it starts to actually disengage the pressure plate from the flywheel. At least that's what I get from his usage of "heel and toe".
It's possible that there's detents on the actual shift linkage as well, allowing you to shorten the throw of the shifter between gears. That might be handy.
Just my speculation though.......
White
Jul 30, 2015 10:23 AM
sk8erjosh09
88
Feb 19, 2015 04:20 PM
chuK_138
Oct 16, 2012 01:12 PM
soverc
Dec 20, 2007 03:34 PM
Sharonaln67
Sep 11, 2006 05:16 PM
