Intake Manifold torque & sequence
Old Aug 5, 2009 | 01:38 PM
cadjoc's Avatar
Default Intake Manifold torque & sequence
Can anyone tell me the torque value and sequence of tightening the intake manifold fasteners? I did a search but didn't find anything unfortunately.
Cheers!
Old Aug 5, 2009 | 02:36 PM
Default Re: Intake Manifold torque & sequence
[quote=cadjoc]Can anyone tell me the torque value and sequence of tightening the intake manifold fasteners? I did a search but didn't find anything unfortunately.
Cheers![/quote
Look in manual in SRT6 section, no sequence given, torque is 15 ft/lbs. Usual sequence is to start in center, slowly approaching correct torque on all bolts in stages while working outward, if my memory serves me right. At 15 ft/lbs I would not think it matters too much.
Old Aug 5, 2009 | 02:42 PM
cadjoc's Avatar
Thanks a bunch! I just needed the value actually as most all sequences start in the middle and work outward and varying top to bottom. I just don't have a manual yet. I did a search and found a link to a thread that said it had a manual to download but nothing was there. Guess I'll have to part with some more greenbacks and get a manual on CD or even an old fashioned paper one.
Get to install the Needswings dual CAI, teflon Y pipe and oil catch can this weekend.
Cheers!
Old Aug 5, 2009 | 02:57 PM
Cheers!
Its on this site. Download it to your computer and you are set to go.
https://www.crossfireforum.org/forum...tml#post111722
Old Aug 5, 2009 | 04:59 PM
cadjoc's Avatar
Absolutely perfect! Thanks a million.
Cheers!
Old Aug 5, 2009 | 10:17 PM
SRT6nTulsa's Avatar
Don't do what I did, and tighten the bottom of the Y piece before installing the Intake Manifolds.
I couldn't get the IMs to match up, and it's because the Y piece was ever so slightly crooked. I tightened the top of the Y piece to the IMs first, then the bottom, and worked like a charm.
The Code 3 Performance phenolic spacers were tedious, but went on fine with the cork gaskets Needswings supplied.
-Alex
Old Aug 6, 2009 | 12:22 AM
cadjoc's Avatar
Hey thanks, really nice tip. So what does everyone reccomend to clean the burnt oil crap out of the manifold? I'm in CA so I have to be very enviro aware. Should I just take it to a local machine shop and have it tanked or?????
Cheers!
Old Aug 20, 2009 | 02:53 PM
cadjoc's Avatar
Well I did the dual CAI, catch can and y pipe mods this last weekend. Cleaned everything with the Awesome cleaner from the 99 cent store. It worked great and the price was right. The only problem I had was when torqueing the bolts to the 15 lbs. Started in the middle and worked fore and aft. Snapped the pass side forward bolt and it was after closing on Friday night.
The next morning I called the Chrysler stealer and they had nothing and couldn't find anything other than a special order. Typical!
Next I started in on the MB guys. They were way more friendly to talk to. Anyway they found a dealer with 3 bolts, all the shorter 65mm length. I went out and bought all 3. One for immediate use and 2 for back up all at $11 + change each. Next I had to go to a differnt dealer to get the stock gaskets. I tried using the cork ones with dressing but they kept moving around too much even when I let the dressing get tacky first. Anyway the stock ones worked much easier and better.
The only other issue was the darn power steering coolant lines. Damn hard to disconnect the rubber hoses and when I did fluid went everywhere. I didn't loose too much since I already had the replacement line in there and ready to go. The real problem was getting the stock tube out. I ended up having to bend it to get it out and hope I won't need it again or else I'll have to get a new one.
Sure am having fun with these mods though. Next isare the pulleys.
Cheers!
syfi
Mar 28, 2026 04:14 PM
blackpepper
Oct 4, 2017 06:09 AM
Dec 2, 2015 12:49 AM
Sep 28, 2015 07:40 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
