How To - Transmission Filter/Fluid Replace
Old Apr 17, 2020 | 02:07 PM
  #121 (permalink)
bc75's Avatar
Default Re: How To - Transmission Filter/Fluid Replace
Do i need to have the front lifted or the whole car on jack stands?
Old Apr 17, 2020 | 03:05 PM
  #122 (permalink)
zip439's Avatar
You can drop the trans pan to change filter with just the front lifted; Please be safe and secure that front end from dropping and set the parking brake tight.
If you are not having any problems you may want to consider removing the plastic cap at the transmission dipstick tube and simple vacuum suction the fluid out of the transmission; Measure exactly what you took out and replace the same amount. Drive the car twenty minutes and then do it again 2 more times. You will have diluted the original fluid down to about the same amount as if you dropped the pan as the fluid in the converter and the cooling lines will not drain by just dropping the pan. Either way works out about the same. Here is a link which may help Trans fluid/filter change
Old Apr 17, 2020 | 08:11 PM
  #123 (permalink)
Red Runner's Avatar
Hi zip439,
I had my transmission serviced by an independent Mercedes shop so I know it was on a lift. Chrysler says to service at 80,000 & Mercedes says 40,000 so I did the 40,000. Also the electric connector on my '04 was leaking. The connector has a small screw that can be broken when installing because of a tight fit. The replacement connector will not leak. That is all I can say.
Old Apr 30, 2020 | 06:23 PM
  #124 (permalink)
bc75's Avatar
Would you change the fluid 2 more times before changing the filter. Or pull the pan and filter the first fluid drain.
Old May 1, 2020 | 08:19 AM
  #125 (permalink)
zip439's Avatar
Read the link I posted in # 122 above. Drop pan and install new filter the first cycle of oil exchange. After you have completed that you can suction vacuum fluid removal of transmission fluid from above through the dipstick tube. ( measure what you remove and add the same amount back in) Drive the car for twenty minutes after putting new fluid in the car will circulate the fluid through the converter for a complete exchange of old and new fluid. You can do that cycle twice.
Many times transmission filter/fluid service is just the one step drop pan, change filter, add new fluid once and you are done, unless you are specific as to be certain the fluid in the transmission and converter is forced flushed at your service garage. AND you trust them to actually do what you requested.
It is a messy job and you do need to purchase some special tools that may be seldom used again, so there are times it makes sense to leave the job to a shop/mechanic you trust.
Old May 1, 2020 | 11:45 AM
  #126 (permalink)
bc75's Avatar
Thanks i dropped the pan today and changed my filter and my connector plug. For only 83,000 miles the fluid didn't look very good.
Old May 1, 2020 | 01:35 PM
  #127 (permalink)
dinasrt's Avatar
That is why the smarter company(Mercedes)says to change it at 40,000.
Old May 1, 2020 | 04:37 PM
  #128 (permalink)
Ronman's Avatar
Mercedes are the ones that initially said to change it 80k and never again. Then later on changed it to every 40k.
Old May 1, 2020 | 09:34 PM
  #129 (permalink)
dinasrt's Avatar
I stand corrected; thanks for that update.
Old May 16, 2020 | 11:00 PM
  #130 (permalink)
Originally Posted by JustSynthetic.com
Hey do you know of anyone who makes a deeper pan for Trans?
For Automatic Transmission: W5A330....SL092
SIGNATURE
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid(ATFPK-EA)
CAPACITIES: 5 speed W5A330 Total Fill 8.5 quarts
5.3 quarts Initial Fill
Yes : https://www.etsy.com/listing/7377936...kaAsghEALw_wcB
Old May 17, 2020 | 09:28 AM
  #131 (permalink)
Fla_Xfire_SRT's Avatar
[QUOTE=zip439;940758After you have completed that you can suction vacuum fluid removal of transmission fluid from above through the dipstick tube.[/QUOTE]
What is this magical piece of equipment that can suck tranny fluid up through the dipstick? Tell me you are not referring to the syrynge thing that we use to suck out supercharger oil. Not with a shop vac either I suppose. Not a vacuum pump like what is used in AC refrigeration work either I suppose. Please enlighten us on how to remove the 3 qts in the torque converter without going to the dealer. I saw a complete kit on FCPEURO website that includes the connector plug, filter, gasket, and conductor plate for a reasonable price.
Old May 17, 2020 | 11:48 AM
  #132 (permalink)
I use the Mityvac 7300 ( uses compressed air, no hand pumping ).
You cannot drain the torque converter, member zip439 recommends changing the fluid 3 times with about 20 miles driving between changes.
That would work, but the fluid is pretty expensive.
I'm have been happy with just the one change.
( why do you think you need to replace the conductor plate ? )
Old May 18, 2020 | 08:21 AM
  #133 (permalink)
~ I feel that with the 0600 code I got, that it may be bad...not for any thoroughly logical troubleshooting reason though...
~ Thanks, I read what zip wrote, and have considered that method, I am intrigued by the the evacuator pump idea that you mentioned. So, my question is about the operation of that device. Do you simply insert a supplied hose into the dipstick tube fully and start the process until no more fluid comes out? Then remove the pan next? This avoids having a full catch pan beneath the vehicle since most of the fluid is in the evacuator?
~ Also, concerning the pigtail connector that looks to be folded and clipped to the rear side of the pan...Are there are connectors on both ends? Can you direct me to a link describing the connector and /or pigtail replacement? ...Thanks
Old May 18, 2020 | 09:56 AM
  #134 (permalink)
That is exactly how the pump is used. The model I got is air powered, so I just insert the tube as you described and sit back with a beer.
When it is done pumping, mark the level on the side of the pump with a piece of tape, that way you can put the exact same amount back in that you took out.
As to the transmission connector, yes replace that. There are countless youTube videos on that, just search 722.6 transmission connector.
Old May 28, 2020 | 10:07 AM
  #135 (permalink)
zip439's Avatar
Late to the party, sorry, didn't see this in my email. As George responded the magic tool is a Mityvac evacuator. I bought the old school model MV7201, but I really like Georges that includes the sit back drink beer option. I also use it exclusively when changing oil; No mess.
Last edited by zip439; May 29, 2020 at 08:08 AM. Reason: different tool/ Power Bleeder 0100
Old Feb 3, 2023 | 11:40 PM
  #136 (permalink)
WD40's Avatar
NAG1 / 722.6 / W5A330 5-speed automatic differences
We got the straight-up "for realz" Mercedes-Benz 722.6 tranny in the Crossfire, no different than in actual Mercedes' cars. I'll include a picture of my car's pan. Notice it's painted black and has a drain plug.
Here's a pan shot of a NAG1 / W5A330 in a 2006 Chrysler 300C SRT8. Notice the pan isn't painted nor is there a drain plug. Otherwise the pan "stamping" is identical such that you could swap the pan from our car to the Chrysler 300C and vice-versa.
https://media.carsandbids.com/cdn-cg...gvW07ymxL.jpeg --- 2006 Chrysler 300C SRT8 transmission pan (URL link)
I just found these slight differences interesting.
2005 Chrysler Crossfire 722.6 black painted pan with drain plug
Old Feb 5, 2023 | 05:25 PM
  #137 (permalink)
WD40's Avatar
Here's our transmission pan application cross-reference list. Notice how the most powerful Mercedes' vehicles (Maybach, SL600 & SL65 AMG, etc.) kept using the 722.6 5spd after all other Mercedes had adopted the 722.9 7spd, since the 722.6 has a much higher torque handling capacity.
Manufacturer's part number:
  • Chrysler MOPAR: 52108327AC
  • Mercedes Benz: 1402700812
CHRYSLER CROSSFIRE 2004-2008
CHRYSLER 300 2005-2014
DODGE CHALLENGER 2008-2014
DODGE CHARGER 2006-2019
DODGE DURANGO 2011-2013
DODGE MAGNUM 2005-2008
DODGE NITRO 2007-2011
FREIGHTLINER SPRINTER 2500 2010-2018
FREIGHTLINER SPRINTER 3500 2010-2018
JEEP COMMANDER 2006-2010
JEEP GRAND CHEROKEE 2005-2013
JEEP WRANGLER 2012-2017
JEEP WRANGLER JK 2018
MAYBACH 57 2003-2012
MAYBACH 62 2003-2012
MERCEDES-BENZ C230 1997-2005
MERCEDES-BENZ C240 2001-2005
MERCEDES-BENZ C280 1997-2007
MERCEDES-BENZ C32 AMG 2002-2004
MERCEDES-BENZ C320 2001-2005
MERCEDES-BENZ C36 AMG 1997
MERCEDES-BENZ C43 AMG 1998-2000
MERCEDES-BENZ C55 AMG 2005-2006
MERCEDES-BENZ CL500 1998-2003
MERCEDES-BENZ CL55 AMG 2001-2006
MERCEDES-BENZ CL600 1998-2014
MERCEDES-BENZ CL65 AMG 2005-2014
MERCEDES-BENZ CLK320 1998-2005
MERCEDES-BENZ CLK430 1999-2003
MERCEDES-BENZ CLK500 2003-2004
MERCEDES-BENZ CLK55 AMG 2001-2006
MERCEDES-BENZ CLS55 AMG 2006
MERCEDES-BENZ E280 2007-2008
MERCEDES-BENZ E300 1997-2009
MERCEDES-BENZ E320 1997-2006
MERCEDES-BENZ E350 2006-2009
MERCEDES-BENZ E420 1997
MERCEDES-BENZ E430 1998-2002
MERCEDES-BENZ E500 2003-2006
MERCEDES-BENZ E55 AMG 1999-2006
MERCEDES-BENZ E550 2007-2009
MERCEDES-BENZ G500 2002-2008
MERCEDES-BENZ G55 AMG 2003-2011
MERCEDES-BENZ ML320 1998-2003
MERCEDES-BENZ ML350 2003-2005
MERCEDES-BENZ ML430 1999-2001
MERCEDES-BENZ ML500 2002-2005
MERCEDES-BENZ ML55 AMG 2000-2003
MERCEDES-BENZ S320 1996-1999
MERCEDES-BENZ S350 2006
MERCEDES-BENZ S420 1996-1999
MERCEDES-BENZ S430 2000-2006
MERCEDES-BENZ S500 1996-2006
MERCEDES-BENZ S55 AMG 2001-2006
MERCEDES-BENZ S600 1996-2013
MERCEDES-BENZ S65 AMG 2006-2013
MERCEDES-BENZ SL320 1996-1997
MERCEDES-BENZ SL500 1996-2003
MERCEDES-BENZ SL55 AMG 2003-2008
MERCEDES-BENZ SL600 1996-2011
MERCEDES-BENZ SL65 AMG 2005-2011
MERCEDES-BENZ SLK230 1998-2004
MERCEDES-BENZ SLK32 AMG 2002-2004
MERCEDES-BENZ SLK320 2001-2004
MERCEDES-BENZ SLR MCLAREN 2005-2009
MERCEDES-BENZ SPRINTER 2500 2010-2018
MERCEDES-BENZ SPRINTER 3500 2010-2018
Old Feb 5, 2023 | 06:03 PM
  #138 (permalink)
WD40's Avatar
Also, forgive my unholy thoughts, but since Chrysler "bolted" the 722.6 tranny to so many Chrysler/MOPAR engines, including their mighty 6.1L & 6.4L V8's, I wonder if anyone ever thought of shoehorning 'those' engines into a Crossfire?
Old Feb 5, 2023 | 08:38 PM
  #139 (permalink)
bluecoupe's Avatar
The first V8 Crossfire was a 6.1L
https://www.supercars.net/blog/2005-...ssfire-v8-6-1/
Old Feb 5, 2023 | 08:52 PM
  #140 (permalink)
WD40's Avatar
That's a Mercedes-Benz M113 6.1L engine though, not the Chrysler 6.1L ESF Hemi.
