Nitrous N/A
Old Jun 29, 2010 | 07:52 PM
BLK04LMTD's Avatar
Default Re: Nitrous N/A
Originally Posted by ruvalcaba
ahh ur going with nightrider style...gl man and hope u get an answer soon. im about to put the nitrous on my xfire today. i only work on my car at nite. not so hot only going 45hp maybe ill go 60hp. dry ofc. ill be going to the track wed. nite hope i can something that is way better than the first run stock.
Thanks, and just a word of advice if you take the carpet off the right side of the trunk in the very bottom back corner there is a square of flame retardant material if you peel that back there is a big rubber grommet under it and you can route the nitrouse line through the corner of the wheel well up through there. That's how I did it, feel the bottom corner of your bumber behind the back passenger tire right next to the gas fume hose you'll feel the hole I'm talking about, perfect location for the nitrous line.
Old Jun 29, 2010 | 11:54 PM
DBLewis's Avatar
I haven't had a chance to look under there for bottle bracket mounting, but is it easy to get to the underside for bolts, and open enough for the blow down tube? I don't know what it is, but I dread drilling holes into this car.
I never cared about the GTI......
-Dave
Old Jun 30, 2010 | 05:26 PM
BLK04LMTD's Avatar
-Dave
I understand your dislike for drilling holes, the only holes I made were in the trunk carpet to mount the bottle other than that the set up is completely reversable and nobody would ever know it was there. The rubber grommet is way big enough to put anything down (my guess would be it's 1 1/2 inches to 2 inches diameter) and out as for the corner of the bumper I don't really know how large that hole is.
Does anybody know where a grommet is in the engine bay for running wires into the cabin?? I can't find one!
Old Jun 30, 2010 | 06:02 PM
SRT SIX's Avatar
Unfortunately, I have no advice to add to this thread.
However, I would like to recognize that this thread is a perfect example of what this forum should be! Looking at the individuals posting, there is a good mix of ages and experience. Refreshing to see cooperation instead of name calling.
Kudos to you all, keep up the good work!
Old Jul 5, 2010 | 11:48 PM
DBLewis's Avatar
Does anybody know where a grommet is in the engine bay for running wires into the cabin?? I can't find one![/quote]
I dont' know if you found a Grommet or not, but
There was a post about guages or something that told of a grommet behind the relay box or something, if you post a question someone might remember it. I tried looking it up and couldn't find it.....
-Dave
Old Jul 5, 2010 | 11:55 PM
DBLewis's Avatar
I know what you mean, I used to be on VW forums, and some questions got old, but a lot of times someone had something new to add to an old question by a newer member. I understand posting a recommended search to help somebody find something, but not blasting someone to do the search because the question has been asked already. Maybe I just have a lot of patience!
And it's kinda wierd, I don't wanna drill holes in the car, but I wanna put nitrous on it!!!!
Old Jul 6, 2010 | 02:09 AM
Infinite's Avatar
Its just a car... drill away. Holes can be plugged with rubber grommets later down the road.
Old Jul 6, 2010 | 09:13 PM
DBLewis's Avatar
I just saw this picture in the gallery from X-fired.
Message - CrossfireForum.org Gallery
-Dave
Old Jul 6, 2010 | 09:38 PM
I found a way in.
Take the shroud off that is above the pedals. (Remove two screws and then wrestle the thing out...)
Now, raise the hood, take the cover off the fuse box next to the Brake's "Master Cylinder" on the driver's side. Using a flat blade screwdriver, pry up the fuse panel and lift it part way out of the box. If I remember right, you pry the FRONT of the fuse panel (toward the front of the car) and the back part of it has tabs that come clear as you pull.
The panel won't come out far, but far enough.
If you use a steel rod or small diameter stick, you can poke your way thru from the fuse box, the stick will show up under the dash to the left of the pedals. Tie a pull string on to the stick and pull the stick out, use the string to then pull your wires!!!
I have a thread on my oil pressure gauge installation AND my "instant cool" switch here where I talk about doing this.
Old Jul 10, 2010 | 10:35 PM
DBLewis's Avatar
I found a way in.
Cool, I'm gonna be running some guage wires soon, and I can get the nitrous wires run through at the same time.
Thanks!!
-Dave
Old Sep 14, 2010 | 12:19 PM
DBLewis's Avatar
So BLK04LMTD, ya got it installed and run yet?
Just Curious...
-Dave
Old Oct 10, 2010 | 12:56 PM
Lakeview NY's Avatar
My last ride was a ford sport trac and I had a wet system on it. I would go with the wet system with this motor. And also start with a 75 shot to start. I was sponsored by nitrous express and I'm thinking about putting one on this car. Any questions let me know.
Billto
16
Sep 1, 2016 11:06 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
cppeabody
Sep 15, 2015 08:43 AM
bdh
Jul 10, 2015 11:22 AM
bdh
Jul 9, 2015 09:40 AM
