SRT-6 Pulley change
Old Jul 3, 2022 | 05:00 PM
Carl Pederson's Avatar
Default SRT-6 Pulley change
Hello All,
I have an 05 SRT Roadster and am considering changing the blower pulley for more HP. Has anyone changed that blower pulley? If so give me the details as to how and what to do. There is a fellow on Ebay in Texas that sells a 64mm pulley with a flash drive and another panel to upgrade the tuning. Has anyone tried that? If so did it work? I'm open to any and all suggestions. Thanks a bunch for any thoughts or ideas.
Carl
Fresno, CA
Old Jul 3, 2022 | 05:27 PM
DTMenace's Avatar
Default Re: SRT-6 Pulley change
Originally Posted by Carl Pederson
Hello All,
Carl
Fresno, CA
Carl
If you decide to go with a reduced supercharger pulley, avoid the aluminum, since several in the past years had imploded and caused major damage. If you decide to go that route, buy a steel one.
I would go with an ASP brand crank pully (177 cm's vs. the stock 155 cm's), virtually no failure rate, with the same results.
Use the SEARCH button and type in supercharger pulley or aftermarket crank pulley, you should find several threads about the subject.
Dennis
DTMenace
Old Jul 3, 2022 | 11:54 PM
Originally Posted by DTMenace
Carl
Dennis
DTMenace
Thank You. If I were to go with the supercharger pulley, do you have any suggestions as to where to acquire one? Also, what is entailed in the programing or tuning?
Old Jul 4, 2022 | 08:12 AM
DTMenace's Avatar
Carl
The attached link is extensive and time consuming to review since it dates back to 2012, including numerous responses, questions about the supercharger pulleys. It's not adding just a pulley, but all of the potential addons to complete the package.
Good luck....
Dennis
DTMenace
62mm SRT6 Pulley Available Now - Page 24 - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Jul 4, 2022 | 10:40 AM
Try talking to Josh Chase at Mercedes Swap Shop. He does tunes and can probably help you with your questions.
Old Jul 4, 2022 | 10:56 AM
if you,,, as i decided to buy the 177 lower pulley from Needswings,,, he has them, I also have a steel stock pulley that needeswings will turne down for me if i want it . do a search u will find lots of info on supercharge pulley
the people on ebay hope you dont know and order theirs then You hope it does not go through the hood
Old Jul 4, 2022 | 11:44 AM
Sussudio's Avatar
Josh Chase (Mercedes Swap Shop) is in so cal. Give him a call you could probably check out his TCU mods as well. Get your SRT6 4 mode sport shifting like the SLR McClaren has. No joke check his videos out on YouTube. Jim’s recommendation of having the stock pulley machined down is also pretty bullet proof. The only other company I know of that makes steel pulleys is MSC. They’re either Russian or Polish. They also have pulley’s made out of Titanium.
Moscow pulleys https://shop.moscowsupercharge.com/product/msc-scp112k/
Mercedes’ swap shop https://themercedesswapshop.com/?page_id=523
Needswings https://www.needswings.com/crossfire-srt6-05-06
ENJOY!!!!!!
Old Jul 4, 2022 | 12:41 PM
ENJOY!!!!!!
Buy from Russia? Not me. If you do, better go through a middleman and not ask questions (IMHO). If you click the website and translate the map, you will see. MOCKBA in Russian is Moscow.
Old Jul 4, 2022 | 01:43 PM
Dennis,
Hmmm...This is a lot more complex than I had thought it was to do. My car has 12k miles on it and is only driven on rare occasions. I had been considering selling it recently, but then got a hair up my hiny the other day when I took it for a ride. I had not driven it for a couple years and had forgotten how fun of a car it is. Then thought a little more zip might be in the mix.
But I think I may reconsider and leave it alone and maybe put it on the market.
Thanks again for the info.
Carl
Old Jul 4, 2022 | 03:59 PM
The MSS tune is cheap, fast and will give you plenty of additional power without the pully change.
Old Jul 4, 2022 | 04:05 PM
Dennis,
Carl
Do yourself a favour and forget the 62 and 65 mm pulleys. If you cannot forget them look back on the history of them. Do not buy a used one as the originals were *****, poorly made and poorly designed.
They were made for a quick buck.
Old Jul 4, 2022 | 04:06 PM
Hi, I am not familiar with a MSS tune. Where do I go to get that info?
Carl.
Old Jul 4, 2022 | 04:29 PM
I just check on line and found EuroCharge. Is this a viable option? Any feedback, experience or knowledge of them?
Old Jul 4, 2022 | 04:33 PM
Thanks for the feedback. It sounds as if I would not be a buyer of the pulley change. Many negatives over the years. I don't want to compromise the reliability of the car. But the ECU change might be an option. Experience for that?
Old Jul 4, 2022 | 04:54 PM
Just look up Mercedes Swap Shop on line. I believe it costs about 350.00 - 450.00
Old Jul 4, 2022 | 05:14 PM
Thanks. Found it. They are over in Ridgecrest. Not far from me. I sent them a message and will likely hear from them tomorrow.
srt6Master
Jul 3, 2016 01:07 PM
RED DOG
Apr 23, 2015 05:49 PM
bluetb
Feb 20, 2013 12:43 AM
bluetb
Feb 19, 2013 09:04 PM
Thumper SRT6
Jan 28, 2009 05:45 PM
