Srt6 with no ECM
Old Oct 15, 2022 | 12:08 PM
Erics XF's Avatar
Default Srt6 with no ECM
Found a srt6 with no ecm for a good price. The problem is the last owner ripped the ecm out. Long story short, the car took the blunt of the anger from a cheating girlfriend.😬 anyway trying to get this car back to its original glory. I don't know if I should get a totaled out srt6 and use it as a doner car and use the ecm. But I don't know if it needs to be re programmed to fit this srt6. The other option I found is taking it to a mercedes dealer and seeing if they can program a new one for it. I heard that can be quite pricey tho.
any thoughts?
Old Oct 15, 2022 | 01:17 PM
Default Re: Srt6 with no ECM
Contact MSS, Mercedes Swap Shop and ask what they can do for you. They are online.
Old Oct 15, 2022 | 01:37 PM
UrbanE's Avatar
Wow
you sure do come across a number of SRT’s without ECM, or is the same one from your earlier September post.
if it’s cheap enough and you’re motivated you’ll be able to make it work.
if you’re considering even the remotest possibility of taking this to a Dealer (MB or Chrysler) then you haven’t done nearly enough homework and dug deep enough into the forum. But if that’s an option you’re considering you should follow it then and let us know what you discover. Nothing quite like going to a dealership for advice on a 17 year old car and asking them for constructive input.
Do the reading here and let us know what YOU think you should do. Don’t ask us to tell you.
My $.02, If you have the skill and desire, I would say buy the car and roll up your sleeves. I know from personal experience that an ECU/TCU/ignition switch/drivers door lock tumbler/ glove box and air bag lock cylinder along with at least one key for and SRT can be purchased for $800 or less
If your budget is tight, it will be a lot less expensive just to buy a running driver.
I am curious about the car without an ECU. you would be buying it blind assuming it’s a runner and the only issue is the missing ECU. If someone has “ripped” it out, it’s been removed for a reason. If you’ve never heard it run, it could become an expensive parts car
just my 2 cents.
Wishing you success no matter what path you select. Keep us updated on your decisions. It could be interesting.
Old Oct 17, 2022 | 09:58 AM
Erics XF's Avatar
Originally Posted by UrbanE
Wow
just my 2 cents.
Same car just changed hands. The guy ended up ghosting me.. my decision was to mail all the parts to mercedes swap shop.
jbp
U.K.
Aug 9, 2014 05:43 PM
turbomar
Oct 9, 2011 08:33 AM
ProjectMayhem
Nov 25, 2008 07:22 PM
stillaneon
Jun 27, 2008 06:56 PM
+fireamx
Feb 9, 2007 02:35 AM
