Faulty alternator
Old May 7, 2023 | 06:43 PM
CurtCrossfire's Avatar
Default Faulty alternator
Hello lovely xfire owners, my alternator has gone 🤦🏼‍♂️ I’ve found a new one for £150 but wondering if it’s a big job to get the garage to do or if it’s something I can do myself, I found the post with step by step to do it but looks as if it’s a tricky one
Old May 7, 2023 | 11:13 PM
Default Re: Faulty alternator
Not hard at all. I've done it three times (here in the states, DO NOT get a rebuilt unit from NAPA).
Anyway, secrets are:
1) Remove fan assembly first.
2) Release tension on belt, then take out the bolts holding the alternator in.
3) Wrestle the alternator out of the mount and slowly rotate it so you can get to the back, disconnect wiring, and pull alternator out.
4) Before putting the new one in, using pliers, rotate and pull on the shims in the mounting holes to move them out a bit, so the new alternator drops right in.
That last one is the most important. It will be hard to get the alternator to let go when pulling it out, by moving the shims out of the way (by just a few millimeters), the new one will go in easier than the old one came out.
File Type: docx
Old May 8, 2023 | 12:10 AM
With the two bolts loosened a few turns try and pry the alternator towards the rear, this takes the clamping pressure off the alternator, As little as .005 movement is enough.
Old May 8, 2023 | 08:48 AM
cheers pizza guy, I’m going to attempt it myself, I’ll let you know how I get on
saltiga
Australia
Dec 30, 2018 07:53 PM
roychez
Mar 6, 2016 04:54 PM
mophreakous
Feb 20, 2012 08:27 PM
Kagen
May 2, 2010 03:51 AM
07bluezx14
Nov 17, 2008 07:42 PM
