Want an easy pop out of the coolant sensor?
Old May 10, 2023 | 04:38 PM
M SL 65's Avatar
Default Want an easy pop out of the coolant sensor?
I find the plastic so brittle around the sensors. I have removed the electric connector on the coolant sensor and am ready to remove the $19 LOL sensor when it arrives. The sensor is in a dark area. Is there a little trick to not damage the white plastic clip? Thanking you in advance.
Sorry, no plastic clip, but a bear of a c clip/ring.
Last edited by M SL 65; May 25, 2023 at 12:39 PM. Reason: Started out looking at the wrong sensor.
Old May 25, 2023 | 04:30 PM
M SL 65's Avatar
Default Re: Want an easy pop out of the coolant sensor?
What is this engine part above the coolant temperature sensor that makes replacing the sensor so difficult? See Pictures.
Old May 26, 2023 | 12:53 PM
That is the secondary air injection pump.
A'naqa
Nov 3, 2021 04:52 PM
chturner
May 18, 2017 09:42 AM
srt6vic
Nov 8, 2010 06:42 PM
Russelio
Nov 18, 2009 02:47 AM
rjoyner17
May 12, 2009 09:26 AM
