Getting my new to me Crossfire on Jack stands, is it possible?
Old Nov 5, 2024 | 10:53 AM
nedj10's Avatar
Default Getting my new to me Crossfire on Jack stands, is it possible?
Hi everyone, new member here.
I just found a 75k mile 2005 and brought it home, I wanted to get the car up on stands to inspect the front suspension and steering components, but I after I found the jack points I note they are barely large enough room for a jack, so just wondering is there some undocumented (safe way) to get the car up on jack stands?
Any guidance is appreciated.
NedJ10
Old Nov 5, 2024 | 12:15 PM
UrbanE's Avatar
Default Re: Getting my new to me Crossfire on Jack stands, is it possible?
I jack it up from the cross member in front and the pumpkin in the rear
for the floor jacks, I have 2 styles. Both work with the jack pads. If you use the jack stands for the pinch weld, you may experience an issue.
Old Nov 5, 2024 | 12:19 PM
nedj10's Avatar
Thanks can you show a pic of where your place your jack on the front cross member?
thanks
Ned Williams
Old Nov 5, 2024 | 12:29 PM
UrbanE's Avatar
Old Nov 5, 2024 | 12:40 PM
UrbanE's Avatar
right behind the splash shield
You will need a really low profile floor jack.
You may also need to drive the front wheels up onto a few 2x8 pieces in order to achieve clearance for the jack
I’ve lowered my car so I need to do that. I also use a thick rubber pad between the jack and crossmember.
hope this helps you out.
Old Nov 6, 2024 | 01:15 AM
I jack mine up the same way as UrbanE.
I drive it up on Rhino Ramps first, then jack up the rear. Then I place a set of jack stands under the rear jack pads. The ramps allow me to get the jack under the nose, so I can lift it high enough to place the front jack stands.
I'm looking to get the "Quick Jack" lift maybe next year.
No clearance issues with Rhinoramps for a stock Crossfire.
Quick Jack
Quick Jack
Astrofriend
Aug 28, 2021 12:09 PM
RED-Fire
Jun 24, 2019 02:58 PM
victorlautreamont
Jun 29, 2017 01:22 AM
Oconnom
Oct 2, 2014 11:09 AM
texas t
Oct 19, 2009 04:57 PM
