how to jack front when swaping tires
Old Jun 24, 2019 | 09:06 AM
RED-Fire's Avatar
Question how to jack front when swaping tires
I need to swap my tires and not sure of the best way, Can a lift in a repair stop be used ?? If so where should it hit under the car..
other wise is there a point where i can jack up the front so that both tires are off the ground??
Old Jun 24, 2019 | 09:40 AM
Default Re: how to jack front when swaping tires
Yes, and yes
For the lift, position the 4 arms to contact the 4 jack points.
For the jack, you will need a low profile one and position it centered on the frame cross member behind the engine.
I you can't get the jack under, then jack up the rear first by placing the jack centered on the differential and then place
jack stands on the 2 rear body jack points.
You can then move the jack from the rear to access that front cross member from the rear, then install 2 jack stands on the front 2 body jack points
Old Jun 24, 2019 | 02:58 PM
RED-Fire's Avatar
Thank You so much !
LARRYG36
Feb 24, 2023 02:11 PM
uknowhim21
19
Mar 20, 2012 11:46 AM
Cissy
Apr 1, 2006 03:18 PM
Joevano
Nov 18, 2005 11:37 AM
lmf101
Jan 18, 2004 10:52 AM
