Day Running Lights
Old May 21, 2013 | 06:02 AM
UK ken's Avatar
Default Day Running Lights
I'm looking to fit day running lights.
Rather than remove all the trim around/under the streering wheel to gain acces to a live
ignition feed...Where is the best other place to get a live feed from
UKKen
Old May 21, 2013 | 06:14 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Day Running Lights
UKKen
Fuse box under bonnet close to firewall on US drivers side. Not sure where it is on your cars. There is a stud terminal that is live upon the ignotion getting turned on near the very back close to the firewall.
I'll post up a previous thread later.
Old May 21, 2013 | 06:18 AM
Hope this helps :https://www.crossfireforum.org/forum...tml#post645463
Click on the pics in this post.
Old May 21, 2013 | 08:12 AM
UK ken's Avatar
Sparkie SRT6..
Thanks for the info..I had no idea there was a live contact there. Make life much easier. Will update you later.
Again, a BIG thank you
UKKen
Old May 21, 2013 | 10:01 AM
UK ken's Avatar
One more question...How do I wire them up, so that they switch off when I use head, dip, fog lights, or side parking lights
UKKen
Old May 21, 2013 | 11:14 AM
11 FEB's Avatar
UKKen
Why do you want them to switch off I would imagine it will take some fancy wiring to get them to turn off when heads or fogs are turned on
Old May 21, 2013 | 11:38 AM
UKKen
If you REALLY want them off when normal lights are on, then run the switched ignition wire through the normally closed contacts of a SPDT relay, drive the relay coil from the hot lead to one of the eyebrow lights.
Old May 22, 2013 | 09:51 AM
xfchris's Avatar
is this the gizmo you need ken...
http://www.ebay.co.uk/itm/DRL-Daytim...item20cc4b477c
or
Daytime Running lights (DRL) Auto switch relay | eBay
or
http://www.ebay.co.uk/itm/UNIVERSAL-...item35c732b3df
Old May 22, 2013 | 10:09 AM
UK ken's Avatar
Thanks Chris..just what I wanted...Now its a case of fitting them.. Next weel I think.
See you Suinday for lunch. ish...Me not the lunch!
UKKen
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
skeet370
Jul 18, 2015 01:02 PM
