**WEBSITE** Functions / Questions/ Suggestions Etc **NOT CAR RELATED** THREADS / DISCUSSIONS Post suggestions or questions regarding the FORUM FUNCTIONALITY etc. The Moderators will monitor postings here
Gas door
Old Apr 21, 2016 | 10:10 AM
Pierantonio's Avatar
Default Gas door
My gas door cable is stretched out so the pin lock won't retract when the door is open. Easiest fix without replacing cable which I understand requires the removal of a few panels in the trunk section. All replies greatly appreciated.
Old Apr 21, 2016 | 10:21 AM
Default Re: Gas door
It's not a cable, it is an air operated solenoid.
You are gonna have to remove those panels and find the fractured yellow air line(s).
They can be repaired by cutting out the bad place, then joining the 2 cut hose ends with a tightly fitting hose of slightly larger diameter.
Old Apr 25, 2016 | 08:56 AM
Fla_Xfire_SRT's Avatar
Concerning the gas door, One of my Xfires has what I call a "sloppy door". The latch works, but when released, it wiggles and is sloppy not firm..no jokes please...How do you access the screws I guess, to tighten the gas door? Thanks in advance.
djohn14296
Oct 12, 2018 05:06 AM
JereRB
Jul 6, 2017 05:09 PM
kstewart
Apr 21, 2016 10:01 AM
jthaub
Apr 19, 2016 06:47 PM
d907ie
Apr 18, 2016 01:14 PM
