Tire Pressure Monitor
Old Oct 31, 2006 | 07:05 PM
ssscott75074's Avatar
Default Re: Tire Pressure Monitor
Originally Posted by danimal
But...I have one more (maybe ridiculous) question. Do you have a good/accurate tire gauge that you are using? Those .99 specials or the built in ones on the air hoses at gas stations can be off by more than 5 psi. If not, you may want to check into something like this: http://valvelock.net/shop/index.cgi
By using a good gauge and checking every few weeks, I have never had a TPM light in the year and a half I've owned the car.
Definitely not ridiculous. I've got one of those pop-out types I've been using for years. I figure it's not terribly accurate, and have considered getting something better. Maybe it's time I did that.
Old Nov 28, 2011 | 06:32 PM
william joe london's Avatar
I have a 05 Xfire Convertable, The manual seems to indicate the Tire Pressure Monitor System is standard.
Right? I have never seen the dash (low pressure)light on at anytime. The car had 9000 mi on it when purchased, but I now see there are typical Shrader valves on the stock rims. What's going on? Mileage is
low so, I assume the tires are original. I don't have the required sensors on any of the tire valves.
Questions:
  • Is the pressure system standard or optional?
  • If standard, why does the pressure lite never show up, even on start up?
  • What may be the explanation for standard Shrader valves and no TMS valves? The car is in mint conditon. Everything looks stock and new.
  • I don't want to spend a bunch of money on valve sensors to find the car doesn't have the system.
  • I could leave well enough alone, but what concerns me is that the low profile tires don't go down much when low or flat and one could ruin a tire quick by driving on a low tire.
Old Nov 28, 2011 | 07:10 PM
bluecoupe's Avatar
Base & SE = no TPMS, LTD & SRT6= TPMS
TerryR
Dec 13, 2019 03:27 PM
Mackel
Sep 29, 2015 02:41 PM
stelrz1
Sep 21, 2015 11:18 AM
tritongreen
Sep 18, 2015 07:32 AM
lazorouss
Sep 11, 2015 09:16 AM
