Rear tire wear on inside
Old Mar 7, 2008 | 09:32 AM
almecum's Avatar
Default Rear tire wear on inside
Hi,
I noticed last night when I looked that the dust on the tires on the rear looked like they are only contacting on the inside half of the tire and not the whole tire. Any idea what is causing this? Pressures are set as they should be.
Old Mar 7, 2008 | 10:24 AM
eganders's Avatar
Default Re: Rear tire wear on inside
Originally Posted by almecum
Hi,
By factory spec they are aligned slightly inward at the top as compared to the bottom. Look at the wheels from the rear of the car to see this.. They should be touching across the entire width of the car.
If you're getting unusual wear on the inside of your tires, take it in for an alignment.
Old Mar 7, 2008 | 10:45 AM
Steve Hellums's Avatar
Hi,
Sounds like the camber is out of spec to me. Bad news is camber is not adjustable. It could possiably be the tow and that is adjustable, but I would lean more to a camber problem. As your springs wear or settle it will cause your tire's to lean in a little more at the top. It's a bad design deal to have no camber adjustment on these cars front or rear. K-MAC sells adjustable camber bushings for the rear, but they are pricey, about $250.
Old Mar 10, 2008 | 10:35 AM
NoCones's Avatar
Hi,
Dust? From where? I'm not sure you can make any conclusions based on dust.
It is likely that what you're seeing is from negative camber in the rear, but doubtful that it's a problem.
If you're seeing unusual *wear*, get concerned. Even then, it's more likely to be due to toe than camber.
Old Mar 10, 2008 | 11:35 AM
RPM's Avatar
RPM
Moderator
Hi,
Is your car lowered?
Old Mar 10, 2008 | 05:03 PM
Moparrbust's Avatar
IRS(independant rear suspension) cars generally have a good amount of negative camber which will cause more wear on the inside half of the tires.
Old Mar 10, 2008 | 07:24 PM
NoCones's Avatar
as long as toe is zero (or very close), a degree or 2 of neg camber will be hardly noticeable (if at all) wear-wise.
toe it out with some negative camber...then you'll start seeing the effects
Old Mar 10, 2008 | 08:40 PM
almecum's Avatar
The Dust was actually powdery dirt on my drive way which was only showing on the inside half of the tire. The car is not lowered, all stock 2004. The one thing I have a issue with this that the car likes to track the lines on the road alot. I live in the northwest so the spikes put some nice groves in the road.
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Jul 28, 2015 08:12 AM
cjfine
Jul 20, 2015 11:58 PM
Buchacho
Jul 9, 2015 04:13 PM
