Help Me, Wheel ?
Old 04-05-2008, 12:20 PM
slow4dr's Avatar
Lightbulb Wheel Problem Sloved I Think
Got my ADR M-Classics put on last Friday and had a few problems, turned out that the guy I bought the wheels from sent me the wrong size hub bore. He sent me 3 that had 73 bore and 1 that had the correct 66.56 bore. So now after spending $200 more I think I have fixed all the problems that this caused. I will get the hub rings on Friday and that should solve the last problem of the car shaking at 60mph. I will have some better and cleaner pics up after I get the hub rings put on but here are a few pics. Tell me what you think about the wheels.
Thanks,
-Chris
Old 04-08-2008, 07:48 PM
slow4dr's Avatar
Default Re: Help Me, Wheel ?
Fixed problems tell me what you think about the wheels, will have more and cleaner pics up this weekend.
Old 04-08-2008, 10:09 PM
newCrossfire's Avatar
they look good!! what diameter are they?
Old 04-09-2008, 03:31 AM
tashspop's Avatar
i agree, they look great. list sizes, offsets, and tire sizes.
Old 04-09-2008, 07:58 AM
slow4dr's Avatar
Wheels are 18x8.5 Front 19x9.5 Rear offset 35 F&R Tires are General UHP 225-45-18 Front 275-30-19 Rear
Old 04-10-2008, 11:20 AM
Great looking wheels! Let us know how the generals ride and hook up. The only thing I would do is put 10mm spacers on back but that is just personal preference.
Old 04-10-2008, 04:23 PM
Yeah I like those too, I was about to get the black mandrus milleniums but now these make the decision harder for my alabaster. If you dont mind me askin, how much and where did you get them from?
Old 04-10-2008, 07:36 PM
slow4dr's Avatar
Talking Re: Help Me, Wheel ?
Thanks for positive commits guys, I got the wheels off eBay from bestwheeldeals; but don’t get them from him. He sent me 3 wheels with the wrong bore 73 and one with 66.56 the right size and he didn’t send me any hub rings or tuner lugs; so I have spent another $200 on top of the $545shipped I paid for the wheels. I think nateswheels sales them for the same price and you can add hub rings and tuner lugs to your order for $40 more but if you get the wheels in the 66.56 bore you want need the hub rings. So talk to the seller before you buy, they will always give you a better deal if you use PayPal without going through eBay.
-Chris
Old 04-10-2008, 07:52 PM
slow4dr's Avatar
The generals are a great tire I have had them on my stock rims for about 9k miles now and they still look brand new. They hook great, are quite, are great in the rain I mean like 4WD 235-70-16 good, and the only thing I would change would be to have a bit more firm feeling when taking hard turns. But they are worth the money got them for $560 m&b. Thought I would go with the BFG because I had them on my srt4 but the $850+ was not in my budget.
Thanks,
Chris
Old 04-11-2008, 01:49 AM
tashspop's Avatar
what is this bore that you're talking about? i'm going to be ordering some wheels soon and need to know details like this?
Old 04-11-2008, 07:34 PM
slow4dr's Avatar
Bore is your Hub bore on your hubs that you mount the wheel to, if that makes sense. 66.56 is the crossfire bore so your wheels need to have a 66.56 bore to mount hubcentric on your hub, so that you don't get any shaking in the steeringwheel. If you don't get the 66.56 bore you have to get hub rings that are the bore of your new wheels and then decrease or increase to the crossfires bore. And on the ADR's you need new shorter lugs because the stock ones are to long on the back wheels. I still need to order these for my wheels I am rolling on so rusty ones the tire shop gave me for free. The treaded part of the bolt (think it is called the shank?) needs to be less than one inch. Or you can use spacers.
Got this off a website: Hub centric rings are manufactured so that when they are installed on a vehicle, the wheels are located directly off of the centre flange of the brake drum or rotor. This is done to insure that the outer beads of the wheel are concentric with the wheel bearings. The result is a much truer, better balanced tire/wheel assembly. This is very important with modern high tech suspension systems.
-Chris
Old 04-11-2008, 07:40 PM
tashspop's Avatar
thank you, perfect responce. i'll be sure to mention this to the wheel supplier i'm looking into. i'm sure they'll make sure i get everything i need.
TerryR
12-13-2019 03:27 PM
Darryl Camisa
10-07-2015 07:10 AM
10-01-2015 01:42 AM
Mackel
09-29-2015 02:41 PM
ritous1
09-26-2015 01:27 PM
Quick Reply: Help Me, Wheel ?
