Finally Lowered my Car
Old Apr 14, 2009 | 10:41 AM
  #61 (permalink)
Default Re: Finally Lowered my Car
I noticed no difference in the ride, and I did not need an alignment.
I hope this helps.
Old Apr 14, 2009 | 01:49 PM
  #62 (permalink)
MisterTaz's Avatar
Code:
by patpu;
have any of you that have lowered your cars had the alignment adjusted afterwards?
Hi Pat,
I can't speak for others but I did need to have my alignment done after the H&R Sports were installed. I also had to get a KMAC kit because the shop could not adjust the camber back anywhere close to stock settings.
In fact I think I have pictures somewhere I took of the rears sitting on the ground where the outer edges of both tires were not making contact at all before the KMAC was installed. I know the H & R Sports are lower than the Eibach's so maybe that is why I needed the alignment?
Right now I have the stock wheels on without spacers until the weather improves for sure. Hope this helps.
Stay safe...
Respectfully,
Paul (MisterTaz)
Old Apr 14, 2009 | 05:02 PM
  #63 (permalink)
patpur's Avatar
Senior Member/Moderator
Thanks guys. According to the shop I talked to they will have to do an alignment? My son concurs on this. Now I'm trying to decide whether to let Sean do it ( the springs) or the shop that does my wheels. Thanks again for the responses FP and Taz.
Old Apr 14, 2009 | 05:06 PM
  #64 (permalink)
Yep, I got two different opinions too. One told me I had to, and the other (the Benz mechanic) said it is not always necessary.
Old Apr 14, 2009 | 07:30 PM
  #65 (permalink)
LantanaTX's Avatar
When I lowered my car, the toe changed to toed out too much and I burned up a new set of tires pretty quickly. You can probably get away with the camber being off as long as you can get the toe right. I went ahead and installed the K-Mac kit and the camber bolts for the front from the dealer. My car is now low and aligned to factory specs.
Old Apr 25, 2009 | 12:02 PM
  #66 (permalink)
Mad_Med05X's Avatar
Originally Posted by FP
I think so. That's what Andrew had on his. As do most of us that have spacers.
Are longer stud bolts needed to run the 12mm rear / 10mm frfont spacers?
What is the rule when it come to safety... How man threads do your lug bolts need to be locked in?
Old Dec 1, 2009 | 09:46 AM
  #67 (permalink)
I would say the rule is; the bolts should be longer by the same extension you're adding the spacers.
Old Dec 1, 2009 | 10:59 AM
  #68 (permalink)
2005 Ragtop's Avatar
All,
For those interested in Tony's (TVT Design) suggested ideal Koni/Eibach/pad combo, see this forum, page 3, 20th post from top titled "Eibachs, Konis and the proper pads"... Post is wrt SRT, but I did manage to get the N/A Limited Roadster addressed (I think).
Old Dec 4, 2009 | 06:36 PM
  #69 (permalink)
07bluezx14's Avatar
When setting up my old cobra suspension, the eibach prokit doesn't drop it enough to require any special kind of alignment extras(parts). But I went all out, with the H&R SS, which was very close to 2" in front, and 1.75 in the rear. tokico illumina adj. shocks and struts. Maximum motorsports caster camber plates. Due to the drop up front, my ball joints went south in a hurry. Swapped out the tie rod endlinks, and balljoints, with aftermarket ones. I also went with a front sway bar twice the size of the original. The car would definately handle beyond my driving skills, when cornering it just stuck to the road amazingly. however anything taller than a pack of smokes, would not clear under the car, found that out driving over a turtle, scared the crap out of me, but sent turtle pieces flying out from under the rear of the car. Sorry about the long post on a different vehicle, but I feel the same applies here as well. chris
Old Dec 4, 2009 | 06:57 PM
  #70 (permalink)
velociabstract's Avatar
I lowered my SRT-6 with the Eibach Pro Kit and Koni shocks. I used the 5 dot pad in the front and 1 dot in the rear. The rear dropped 1 1/2 inches and the front 1/2 inch. The front just barely rubs in some situations but I have 4mm taller tires than stock. The rear has room to go lower. My front camber stayed the same. I don't know about the toe. The rear camber changed. Oh, I used the pads Tony suggested in that thread, he was right on the money.
Les
Old Dec 6, 2009 | 08:25 PM
  #71 (permalink)
1sexyXfire's Avatar
Looks awesome! I just ordered new wheels for my '04. Gotta get springs and spacers next check!
Old Dec 6, 2009 | 09:19 PM
  #72 (permalink)
LantanaTX's Avatar
When you get your wheels, meaure the hub thickness and compare to the thickness of your stock wheels. Any difference needs to be taken into account along with the spacer thickness to figure the wheel bolt length.
Old Dec 10, 2009 | 11:06 PM
  #73 (permalink)
1sexyXfire's Avatar
Appreciate the info. Thanks!
Old Dec 11, 2009 | 03:04 PM
  #74 (permalink)
Z28toXFire's Avatar
Yeah it took me a couple of tries to get the spacers and lug bolts right, i am definitely a cut twice first kind of guy though.
I have mine on H&R's. and TSW wheels, with Spacers. i never cut the bump stops, and am sorry i didn't.
I will when i get my set of Bilstein shocks.
Thanks,
Justin
Old Dec 12, 2009 | 07:03 PM
  #75 (permalink)
Juggernaut's Avatar
Originally Posted by andrew
without spacers:
with spacers:
looks much better pushing the rim & tire closer to the wheel well edge imo ... hope this helps!
Definitely looks cleaner with spacers on.
Old Dec 12, 2009 | 07:42 PM
  #76 (permalink)
MikeR's Avatar
That is probably the best pics I have seen to show the difference in setup with and without spacers.....thanks.
Old Dec 13, 2009 | 05:53 AM
  #77 (permalink)
Veloce's Avatar
Wowzer.
Is there a DIY?
Old Dec 17, 2009 | 01:06 AM
  #78 (permalink)
1sexyXfire's Avatar
Juggernaut, How low did you drop your ride? Where did you get your spacers? Looks real cool!
Old Dec 17, 2009 | 05:24 PM
  #79 (permalink)
That's Andrew's car.
Old Jul 10, 2010 | 02:33 AM
  #80 (permalink)
firemen's Avatar
Thanks,
Justin
Look simple but nice, not bad. It fits to your car. I just ordered the same wheels for my car but still waiting on shipping. i will send pics once i get 'em and have them mounted on car. i personally like them cause they are different.
