Wheel alignment / camber
Old Jan 16, 2009 | 09:48 AM
hooshcrossfire's Avatar
Default Wheel alignment / camber
had my mot done today and damn my rear inners r worn so bad! guy suggested getting the wheels aligned and camber adjusted!
can anyone suggest somewere in nw london? or tell me what needs to be done incase i see place thats offering services
Old Jan 16, 2009 | 06:56 PM
cheap ride's Avatar
Default Re: Wheel alignment / camber
I hit a concrete curb with the right front wheel hard enough to skin the rim up pretty good. I replaced the wheel with a new one then wanted a 4 wheel alignment check done. I'll make it short . The caster/camber was out a few degrees. It requires a special bolt kit that is obtained from Chrysler (or I have a hunch Mercedes as well) The kit has offet washers in it to perform the proper alignment. It costs about $80 if I remember correctly.
If I were you I would go to a Mercedes dealership and ask them to perform the work. They will be experts whereas the Chrysler people aren't usually. It took my crew all day to do a 2 hour alignment. They were learning as they unpacked the kit.
Good luck, Jim
Old Jan 16, 2009 | 08:02 PM
BrianBrave's Avatar
<--- Huge Horsepower
Front camber bolt kit M/B Part # 2023300118 - $19.00 Ea. (one bolt)
Old Jan 20, 2009 | 01:45 PM
Steve Hellums's Avatar
When I lowered my car I was concerned about the camber so I ordered some rear adjustable bushings called KMAC rear camber kit from a place called import auto performance. If I remember right they were on EBay. And I also got a set of bolts for the front like Brian had posted.
Old Jan 20, 2009 | 02:33 PM
BlueStorm's Avatar
the KMAC's are no good if you race but decent for street,
there is a guy on MBWorld who sells REAL camber adjusters, not the funky KMAC stuff, you can make them yourselfas it is a simple design. just a turnbuckle with aircraft universal joints.
He also makes a really cool lowering kit for the mercedes benz a-arms so you can lower your car with stock springs, just by turning a simple bolt. I think he's located under the MBZ 210 race groups
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
