caliper paint
Old Apr 15, 2010 | 02:23 PM
swagg215's Avatar
Default caliper paint
I knw its prolly a hundred post about this but i really cant find any so... I wanted to paint my SSB xfire calipers white and i didnt knw if i needed to put primer on it first after i cleaned it or do i just clean em and put the caliper or engine paint on...if i can get a step by step that would be great
Old Apr 15, 2010 | 02:53 PM
MikeR's Avatar
Default Re: caliper paint
Just clean them really good and have at it. Scuffing them up a little first wouldnt hurt... make sure you mask everything and dont paint the rotors...
You can do them real easy if you take them off the car... but then you have to deal with the brake lines and bleeding them to get air out when you put it back together... if you install SS brake lines while your at it you win all the way around....
Old Apr 15, 2010 | 02:55 PM
mdaniels4's Avatar
Painting them with a primer is probably best to get the top coat to stick better, maybe not necessary but absolutely won't hurt. Especially since you're going white. Just clean them well, andd paint away. I need to get mine off to paint them orange, but I can't seem to find the time to do it.
Old Apr 15, 2010 | 03:57 PM
OKC-XFR's Avatar
The key is lots of brake cleaner, a wire brush and lots of masking tape. I painted mine when I replaced my pads and rotors, so I had the calipers off the brackets, but didn't disconnect the brake lines...I didn't use any primer and it's holding up very well.
xfireohio
Jul 20, 2020 12:03 AM
ATX SRT-6
Oct 12, 2015 03:16 AM
maxcichon
Sep 25, 2015 02:55 PM
ozkancab
Sep 25, 2015 10:55 AM
stryfox
Aug 30, 2015 02:44 PM
