Wheel guru's help needed...
Old Mar 8, 2011 | 01:25 AM
SoftballJunnkie's Avatar
Default Wheel guru's help needed...
So I want to a wider mean stance for my rear. Right now I am running a hub centric rings on all 4 tires. Rims have a OD of 72mm stock is 66.56mm
I am at a offset at 40 in the rears.
Do I need hub centric spacers to do this properly? If so whats my best fit to get the centerbore back at stock and my offset back to stock? Whats the best place to order from?
America's tire said they are highly against any kind of spacers, but i want a more wider stance like I had at stock.
TIA.
Old Mar 8, 2011 | 07:40 AM
maxcichon's Avatar
Default Re: Wheel guru's help needed...
For a 20 mm offset (40 mm to 20 mm) I would look at Eibach Pro Spacers and I'm afraid you'll be stuck with using the centering rings for the bore mismatch. I presume this is for the rears only?
JMHO
Eibach Pro Spacers 90.2.20.007.1
Old Mar 8, 2011 | 12:45 PM
JMHO
Yes, its for the rear only. So I can havbe both hub centric rings and spacers together?
Old Mar 8, 2011 | 01:33 PM
Max, I just ordered these they will be here tomorrow. I'll post pics.
Old Mar 8, 2011 | 01:35 PM
maxcichon's Avatar
I've not done this, but the rings should fit inside the bore of the spacer just the same as the wheel. Kind of a sandwich, but should work just fine.
The Eibachs come with a set of lug bolts to attach them to the vehicles hub. Then you'll need bolts to attach the wheel to the Eibachs. I would presume that the ones you have now will work for that.
Old Mar 8, 2011 | 01:38 PM
Yeah hopefully everything goes well. I just bought a set for 81 shipped via Amazon. Went back to Amazon they are 170 right now. I guess I got a good deal.
Old Mar 8, 2011 | 02:49 PM
maxcichon's Avatar
Yes, you did!
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
