New photos of Mandrus Wilhelm
Old Sep 8, 2011 | 06:32 PM
  #41 (permalink)
Airscape's Avatar
Default Re: New photos of Mandrus Wilhelm
Skyline drive a couple weeks ago
Old Sep 8, 2011 | 08:38 PM
  #42 (permalink)
JHM2K's Avatar
Looks fantastic!!
Old Mar 11, 2012 | 10:17 PM
  #43 (permalink)
nate_man's Avatar
Originally Posted by JHM2K
What offsets did you get?
I got 18x8.5 +32mm in the front, 19x9.5 +25mm in the rear.
OEM is +35mm and +22mm, front and rear, respectively.
JHM2K,
Just curious if you considered a 19/20 package.
I went with those for my milleniums and like the size difference.
Just wondered if you considered that option.
Nate
Old Mar 11, 2012 | 10:21 PM
  #44 (permalink)
JHM2K's Avatar
Originally Posted by nate_man
JHM2K,
Nate
Definitely considered it, but when I got the wheels last year the tires were still fairly new. Figured I'd used what I had.
I do love the 19/20 look, it's an eye-popper
Old Mar 19, 2012 | 10:24 PM
  #45 (permalink)
BUGG DOMI's Avatar
JHM2K and Airscape are those the chrome version of the wilhelm or the silver version?
Old Mar 19, 2012 | 10:45 PM
  #46 (permalink)
JHM2K's Avatar
Silver w/ machined face on both
Old Mar 19, 2012 | 10:53 PM
  #47 (permalink)
Squirrel Crusher's Avatar
Good Choice..Squirrel Crusher
Old Mar 20, 2012 | 12:45 PM
  #48 (permalink)
BUGG DOMI's Avatar
JHM2K I ssume these are the ones you had put on them. Let me know. If so I might go with the same choice myself.
http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-112&yr=2004&pc=70210&counter=3&wd=19&rw=9.5&vid=01 4291
http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-112&yr=2004&pc=70186&counter=5&wd=18&rw=8.5&vid=01 4291
If so did you have any problems during the install. The people around here have no clue so I would like as painless an installation as possible.
Old Mar 20, 2012 | 01:13 PM
  #49 (permalink)
Airscape's Avatar
I ordered mine mounted/balanced with hankooks on them, pulled the jack out and did them all real quick, no issues/anything special. Would recommend a 235 up front vs the stock width though. If you are getting rubber separate/local just make sure the shop you go to can mount/balance the 19" some smaller shops may not have a big enough machine to do the job but that is probably pretty rare.
Old Mar 20, 2012 | 02:14 PM
  #50 (permalink)
JHM2K's Avatar
Yes sir, those are the exact ones you need.
As Airscape mentioned, you can order them mounted and balanced if you prefer. If you have a local Discount Tire, it's sometimes best to let them handle the tire installation as you can have a "support group" handy should anything go wrong with one of your tires. They are generally excellent about looking out for their customers.
Old Mar 21, 2012 | 10:32 AM
  #51 (permalink)
BUGG DOMI's Avatar
Thanks for the info.... The problem here is I am not buying new tires as the ones I currently have on my stock rims have plenty of tread life left in them. My plan was to just order the wheels and have the tires taken off the stock rims and put onto the new rims.
Old Mar 21, 2012 | 12:13 PM
  #52 (permalink)
Airscape's Avatar
This is not an issue up front, the tire will look a bit stretched though, in back I am not sure, someone else may need to chime in. 285 is perfect for this setup, I think 9.5 may be the maximum rim width for a 255 so you will be stretched pretty far. Best to ask the place you are getting it done. You can check the first page for my pics, the last one is the 285, pretty much perfect flush with the rim and slight protection, a couple up you can see the front 225 is stretched a bit and does not provide much protection. I havnt had either touch a curb yet (park on a street at work daily) but just something to be mindfull of as well, 255 will not give you much buffer in the back. Personally if you can swing it I'd get rubber as well, if you have PS2s or something like that they should be pretty easy to sell here. Again someone more knowledgable may be able to give you a better opinion than I.
Old Apr 11, 2012 | 08:48 AM
  #53 (permalink)
Airscape's Avatar
Finally happened, hit the curb this morning. Was too pissed to really take a look at it but I can't stand rash so they will need to be fixed. Anyone know of these are clear coated? I can probably do the sanding and polish myself but not sure if it is worth it if they will need to be coated again, may just get a shop to do it. Thanks!
Old Apr 13, 2012 | 10:30 AM
  #54 (permalink)
Airscape's Avatar
They are coated #foundoutthehardway
Old Apr 13, 2012 | 10:33 AM
  #55 (permalink)
JHM2K's Avatar
Damn, no bueno.
Looks like I'll be buying C63 reps after all, LMAO
Old Apr 13, 2012 | 11:24 AM
  #56 (permalink)
Airscape's Avatar
Damn, no bueno.
Lol, someone had to be first to f$&@ it up. Good news, sanding the rash down works like a champ, bad news definitely coated. I should have known by how easy the dust wipes off of them but for 250 a rim I was not too worried about it.
At this point I can probably call the mobile wheel repair guy and get it done for 100ish or pick up some 3000grit and a can of wheel clear and see how good I can get it matched up. It doesn't look bad currently and definitely better than the rash, the shine is just not uniform.
Old Apr 13, 2012 | 01:00 PM
  #57 (permalink)
JHM2K's Avatar
I would attempt this before spending the $$$ on a full-blown repair. Look at it this way: they're going to perform a strip and repaint anyways, you may as well have made the effort. If the sand/repaint DIY works well, I may try that on my rim that was rashed courtesy of the tow truck
Old Apr 13, 2012 | 02:57 PM
  #58 (permalink)
Airscape's Avatar
Will post results this weekend. If yours are not deep and at the edge, a careful light sanding right on the rash followed by a good polish/wax will probably be unnoticeable the edge is the most uniform as far as the shine goes and you can't tell, it's the flat part of the lip that is the problem. I feel like such a jackass but to my credit I park on the street every day and pull up to the curb at least twice on average at work so 1 mistake out of a couple thousand tries isn't too bad. When I did it I did it big though
Old May 11, 2012 | 10:58 AM
  #59 (permalink)
Airscape's Avatar
Sorry I have been slacking on the update. I did mess with it that weekend but ran into another issue. First the only wheel clear (duplicolor) that I could find locally did not like to stick to the metal, while this was a problem it was not the main one. I do not think there is a clear coat but instead some sort of shiney covering, paint or otherwise. I sanded and polished the lip to super **** levels and could not get it to look quite as shiney. I'm not sure exactly what it is, some kind of film or paint unless they can magically make it shine brighter than I could after buffing the **** out of it. Once I had it as clean as I could get I just did a coat of wax and have been driving it daily since then.
First I am happy with the results after all is said and done, much much better than the rash. There are basically 2 lines where I stopped sanding on the lip and my polished metal meets the shiney covering. Way less noticeable than rash and even I have to take a second to find them. My thought was that my section would accumulate dust differently than the rest but not the case this far. May be the wax but time will tell. Been out in the rain, through washes and has not dulled or discolored.
I would recommend this route as the cheap fix for sure. If the rash is small and right on the edge careful sanding right on the spot should be basically invisible. If you have to do the flat part of the lip going around the entire thing may be the better option. The border that is created on the curved part of the lip is not noticeable as long as you keep it consistent. Will add pics soon.
Old May 25, 2012 | 07:14 PM
  #60 (permalink)
Airscape's Avatar
Pics
start of rash, goes around almost 180, ill save the pain of showing the whole thing
Low Grit Sanding
More low grit to smoothe out those deep cuts
After a lot more sanding, after first round of high grit
Pretty much done, ready for the paint failure.
Post clear failure strip off, (basically another 3000 grit sanding) metal polish and wax application
Can post some close up pics of seem, can see it on the last pic 3 and 9 o clock. You could probably shape it sharper with some careful sanding so it wouldn't be a strange shape like mine and it would blend with the shine, I sanded way past where the rash ended to try and blend but whatever covering they have on em could not be matched by me no matter how much I polished. Maybe some of the chrome like paint would do. Again I would say just do the whole outer ring, I can do some more close ups if anyone is interested.
