NA XF's "Odd" Spoke Wheel
Old Jul 7, 2011 | 12:51 AM
+fireamx's Avatar
Default NA XF's "Odd" Spoke Wheel
Does anybody know the reason the back side of just one of the 7 spokes on the front wheels only of the Limited/Base cars, is different from the rest?
Old Jul 7, 2011 | 12:53 AM
Default Re: NA XF's "Odd" Spoke Wheel
Is this a quiz or a real question?
I never noticed but at one oclock in the morning, I'm not going outside to look.
Unless there is something in it for me.
Old Jul 7, 2011 | 01:33 AM
+fireamx's Avatar
It's a real question Franc. I noticed the difference today while cleaning the back side of the rim.
I couldn't figure out why there was a different design to just one spoke.
I didn't have the rear wheels off yet, but all the spokes felt the same when I checked.
The difference is at the very bottom of the spoke where it meets the rim.
If you reach around behind it you can easily feel the abnormality with your finger. (Did I just say that?)
Old Jul 7, 2011 | 02:14 AM
jmk41's Avatar
Mike i bet its for the TPMS nothing else would make sense unless it has to do with the machine used to cut them and grip them i highly doubt they are a forged wheel so a mold is out of the question.... Could have something to do with balance as well maybe to off set the stem weight? I would have to lean more tward the TPMS tho
Old Jul 7, 2011 | 07:32 AM
dtinker's Avatar
May have something to do with the casting method of the blank? Not having looked at the difference, it could be for the weight change of the TPMS.
Old Jul 7, 2011 | 10:52 AM
+fireamx's Avatar
Thanks guys, it was no big deal but I was just curious.
Old Jul 7, 2011 | 05:19 PM
Definatly the TPMS. Can you imagine how many weights would have to be glued to the side opposite the valve stem if the Germans didn't tell the Poles ( the wheels are made in Poland ) to make that spoke thinner to offset the 3-4 ounces that the TPMS weighs ?
Old Jul 7, 2011 | 05:22 PM
WAIT - that don't make sense. That spoke would have to be THICKER, not THINNER.
My final conclusion : I ain't got a clue.......
Old Jul 7, 2011 | 05:24 PM
Originally Posted by andrew
~ for the valve stem area.
Now, that make sense. Less weight in the spoke coincident with the TPMS.
Old Jul 7, 2011 | 05:25 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ it is the spoke that housing the valve stem.
Old Jul 7, 2011 | 05:30 PM
andrew's Avatar
~ i'm wrong... it must be the weight thing... because it's most likely the spoke at 180 degrees from the valve (not located on a spoke as i thought).
Old Jul 7, 2011 | 05:44 PM
I'm sure it has to do with overall balancing of the wheel/tire assembly. Probably to minimze the weight required to balance the assembly.
Back in the "good old days", tires were marked with a yellow dot to indicate the "high spot" of the tire rotational balance. That was suppose to be aligned with the valve stem where the "low spot" was for the wheel. "Best Practice" has all but gone by the wayside nowadays. Partly with the advent of TPMS (which changed the rules); partly because a tire changer at most multi-service shops is the entry level position. You just about have to go to a Discount Tire shop or something similar where all they do is mount tires & wheels. Those guys usually know the optimum geometry for mounting a tire to a wheel. You really want only the minimum weight necessary to balance the tire/wheel assembly.
Old Jul 7, 2011 | 05:46 PM
TomStratRT's Avatar
Too much time on your hands man.
Seems that the different spoke (bottom) is opposite the valve stem (top)
Here is a pic of a clean spare front for my NA...
Old Jul 7, 2011 | 05:58 PM
If you look at the bottom of the spoke where it mates to the rim, there is extra material along the rim. Most likely to compensate for the TPMS unit at the valve stem opposite this spoke.
Old Jul 7, 2011 | 06:00 PM
I knew that it was not April 1st, but I have to wonder how many people are getting their finger tips black from poking around where the sun don't shine.
It is the spoke opposite the TPMS sensor and is therefore to offset the weight of the sensor. My one obviously is way out of balance and has five weights stuck there as well.
Old Jul 7, 2011 | 06:03 PM
Wonder of aftermarket rims are designed this way? Might not be because of not knowing beforehand whether you have TPMS or not.
Old Jul 7, 2011 | 06:04 PM
Tell me about it!!
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
