Slow leak from Wheel
Old Sep 3, 2011 | 04:52 PM
killerkanadian's Avatar
Default Slow leak from Wheel
Hey guys, I have this problem. My old set of tires my driver side rear wheel would always lose air and trip the TPMS and eventually go completely flat. Now i have brand new tires on the car and i still have the same problem. What do you guys think is wrong or i can do about it? Do you think part of the rim of the wheel is damaged or something to do with the TPMS stem? I really don't know how to go about this other than buy new wheels which i want to do anyways
Old Sep 3, 2011 | 05:20 PM
Default Re: Slow leak from Wheel
The first thing to do is use soapy water to find the leak and go from there.
Old Sep 3, 2011 | 07:15 PM
Double check for a cracked rim or leaky valve stem, with the soapy water. You will have to remove the wheel and check inside real well.
Old Sep 3, 2011 | 07:52 PM
Bigkid's Avatar
KillerK I had the same problem and it was a crack in the rim for me. good luck finding the problem and a solution.
Old Sep 3, 2011 | 08:06 PM
Thanks guys, I guess I could of figured this one out myself. I'll take the tire off and fine tooth comb it with some soap and water.
If it turns out being a crack in the rim, can a wheel and tire shop fix it?
Old Sep 3, 2011 | 08:46 PM
My guess is that a regular tire shop will not touch it. However if you have a local company that repairs/refinishes wheels, they will repair it back to original condition. I have one local, The Wheel Dr., that does excellent work and I wouldn't hesitate for a second to have it repaired by them.
Old Sep 3, 2011 | 08:54 PM
Guess ill just have to call around once i find the leak. Otherwise ill be filling it up every weekend when i drive it.
Old Sep 3, 2011 | 08:56 PM
Hopefully you just have a bad valve. You may have a bad TPMS as well.
Old Sep 3, 2011 | 09:01 PM
Yeah hopefully it could be the valve. The tire definitely goes flat though.
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
