why isnt my car low after the install
Old Dec 21, 2011 | 06:44 PM
lionroarXF's Avatar
Exclamation why isnt my car low after the install
hope some of you on the fourm could help me out with your input...well had my eibach pro kit installed ythe other day. and the rear seem to have dropped almost at once after i drove up the street but the front hasnt..it had been 2days and the front hasnt seem to be dropped.....wht could it be?...btw i have the 04 with the srt rims and 40mm profile tires all arround. does it take time for these pro springs to settle on our cars? how long did it take yours to fully drop if so?...
Old Dec 21, 2011 | 07:15 PM
MikeR's Avatar
Default Re: why isnt my car low after the install
the car should drop immediately.... it may settle a little more over the next few days/week.....
make sure the springs are seated in the recesses and in the spring pads on top....if both ends were not in the seats that could make a fair difference.....
I recall one other person having a problem with front not going down after install but cant remember who and what the solution was.....
Old Dec 21, 2011 | 07:26 PM
lionroarXF's Avatar
am crossing my fingers hopeing that it will drop lower in these couple of days.. i really hope tht person will come up and say wht was done to make it sit proper. but thanks mike for the quick response
Old Dec 21, 2011 | 07:47 PM
hcarter's Avatar
Sounds like the springs are in the wrong position in the pads not seated the car should go down as soon as the weight is put on the springs ..they will not settle any more if this is the case.
Old Dec 21, 2011 | 08:19 PM
velociabstract's Avatar
What spring pads did you use? With dot 5 in front you only drop 1/2 inch in the front. The pro kit drops the rear more then the front but which pad makes a lot of difference.
Les
Old Dec 21, 2011 | 11:42 PM
lionroarXF's Avatar
oh man.... now am a have to take it back to where i had it installed at, hope they dont charge me.
i left the stock pads on
Old Dec 21, 2011 | 11:51 PM
arejohn's Avatar
On Miatas the rotational torque on the bushings can prevent complete lowering and must not be tightened until the suspension is loaded.
Old Dec 22, 2011 | 05:51 AM
32krazy!'s Avatar
stock pads would be a 1 or 2 dot. when installing lowering springs the fronts are usually a 3 to 5 dot pad are used as that fine tunes the drop. its only 4 mm per dot. you have another issue unless they added pads on top of the stock pads
Old Dec 22, 2011 | 05:52 AM
32krazy!'s Avatar
if the shop used the proper tools to remove and reinstall the springs no bushings are disturbed. on the sway bar bolts shock bolts are removed during the swap. 20 min job
Old Dec 22, 2011 | 06:02 AM
hcarter's Avatar
They should not charge you anything more if they incorrectly installed the pads . Besides if they have the right tools (spring commpressor.) should go quick.
Old Dec 22, 2011 | 06:10 AM
The stock pads are fine and won't cause your issue. I had too much drop with the stock pads.
Les
Old Dec 22, 2011 | 10:06 AM
My car came with dot 5 pads OEM, so I think they used everything and only 1 way to know, take it out and look, or feel the 'bumps' on the rubber stop while it is in place.
The other thing to consider, is if your front springs were broken (both of my front springs had nearly a coil broken off them) that you will not see that big of a drop. Just a possibility. Also, if you are redoing it, I would make sure to cut the bump stops on the shocks so you dont bottom them out...
Old Dec 28, 2011 | 09:58 PM
lionroarXF's Avatar
thanks guys... so it has been almost 12days with my springs on. the car is feeling like its sitting how it was toled tht it should, riding smooth. i would say the stock handling was still better but conering is superb with these springs on. overall riding smooth thanks for all the help
Old Apr 3, 2012 | 02:58 AM
cameronjfoss's Avatar
Talking Re: why isnt my car low after the install
What did you use? Pic of the side of your crossfire?
Old Apr 26, 2012 | 11:06 AM
thekid91's Avatar
i bought the same kit and i dont have any srt stuff on mine and my front dropped to where the wheels are flush with the wheel well and my rear tires dropped a bit but when i park it it looks kinda funny like the springs havent settled either. i freaked out but guys on here said its because they havent settled yet
Old May 1, 2012 | 10:57 PM
chewy123's Avatar
i bought the eibach pro kit and mine has the front lowered 1.10 inch. and the rear: 1.30 inch. ... my question is that , will it make a difference in the looks of flush or not or the look of a lowered car in that matter ?
Old May 2, 2012 | 08:36 PM
hcarter's Avatar
I am using only the rear Eibach Pro springs on my 6 with dot4's the fronts are the stock srt springs with 1 full round taken out. with the koni's ' and my car sits pretty low. both front and rear tires are under the fenders no gap. it ...i can tell you it is possible to get a ride just as good or better than stock but you have to get the rear sway bar to a neutral position and the camber correct to make it happen with a lot of tweaking .but when you get it there these cars become a totally different handling beast and worth every penny spent . every car setup is going to be a little different but the outcome should be the same ,a great handling ride... I love the rush of driving when the car is really hanging in the turns and you can feel the horrizonal G's ...mucho fun. Yes I;m bragging on my 6.....
Howard.
rayth
41
Jul 31, 2019 04:02 PM
BEATv1
Jul 16, 2015 09:40 AM
rmcdaniel12
Jul 1, 2015 12:49 PM
chturner
Jun 23, 2015 07:21 AM
WindRestrictor
Jun 1, 2015 02:31 PM
