alignment questions???
Old Feb 21, 2012 | 05:31 PM
07bluezx14's Avatar
Question alignment questions???
I bought my car used with brand new forte wheels and tires. Yesterday I noticed that on the inside tread on both front tires about 1-1 1/2" are totally bald. I have had the car for around two years but only put around 9000 miles on it. I am hoping that this is an alignment issue. What I am thinking is that they installed the tires and wheels and didn't align it. The front tires are too skinny for the wheels 215/35/19's. There is atleast a 1/4" of wheel sticking beyond the tires. Im not sure of the offset but it feels pretty close behind the wheels. Any Suggestions? I have to figure this out quick.
Thanks, chris
Old Feb 21, 2012 | 06:20 PM
velociabstract's Avatar
Default Re: alignment questions????
My guess would be an alignment problem. If the toe is off by much it will eat the tires rapidly. A skinny tire on a wide rim shouldn't cause this IMO. (I have 245/35/18's on a 9" rim) But I'm not an expert. Just observant.
Les
Old Feb 21, 2012 | 06:38 PM
MikeR's Avatar
yes, it sound like an alignment problem... is the car lowered? that will give you negative camber in front and back and wear out the insides of your tires....
the previous owner may have put the 215/35's on to get clearance from the nut on the upper inside of wheel well with the new rims..... you need to check that and see how wide a tire you can fit on those rims.... I would think you should be running a 225 or 235.... you may have to go to a 30 profile tire to get the clearance you need.....
Old Feb 22, 2012 | 05:52 PM
07bluezx14's Avatar
The car isn't lowered, and I agree with the size. I mentioned the tires to the dealer after the first week, but he was unwilling to do anything about it, since I had put a few miles on them. Hell even the door says 220 or something. I kinda felt around behind the top inside part of the wheel, and it's close. If I used spacers the wheels might stick out past the fender. I'll have to take a closer look.
Thanks, chris
Wish it were a little warmer I would ride the bike while I figure all of this out.
I have to put a new tire on the back of it every year as well
Old Feb 22, 2012 | 08:02 PM
MikeR's Avatar
The back is easy to fix..... I make adjustable links that will let you get the camber dialed where you want it... PM or email me if you have questions..
Old Feb 23, 2012 | 09:37 AM
sk8erjosh09's Avatar
So Toe on the front can be adjusted, but not camber? and The rear has no adjustment at all?
Old Feb 23, 2012 | 11:02 AM
MikeR's Avatar
The front wheel camber is adjusted by replacing a set of bolts in the lower control arm...it is only a small adjustment... or you can buy the Kmac kit that replaces both bushings in the lower control arms with poly bushings and eccentric bolts and have plenty of adjustment...
The factory rear camber is a fixed strut, no adjustment. Your options are adjustable camber struts or another Kmac kit for the rear....
Old Feb 23, 2012 | 11:37 AM
Now Im extremely curious why my rear tires are wearing so bad on the inside. I noticed it a little a while back and thought it was just an alignment problem. The front is the same way but not as bad. I have new ish tires but the back ones are pretty darn worn on the inside about 1".
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
