Tire valve broken!?
Old Mar 19, 2013 | 04:20 PM
MyFire91's Avatar
Question Tire valve broken!?
I just recently got my 05 Crossfire and the tire pressure light was on so i decided to go to my local gas station and fill them up with air. To my surprise, the tire valve on the front driver side seems to be broken and wont let me put air into it! it has some air in there but i want to fill it up to 32psi. it wont let me read the current psi and im afraid of driving like this. When i try to stick the air hose thing on there it only releases the current air inside the wheel already. What can i do!??
attached is a picture of the valve!
Old Mar 19, 2013 | 04:26 PM
Default Re: Tire valve broken!?
You need to go to a tire repair shop and have the valve stem replaced. Probably got curbed or something. You might be able to use a pair of needle nose players and round out the opening but I think I would get it replaced.
After enlarging the photo. Go directly to the repair shop. Don't be driving it.
Old Mar 19, 2013 | 04:45 PM
There is a part missing and the whole thing needs to be replaced. That is the Schrader valve showing and that is hidden by the broken part that is missing. Take the tire to a tire shop and get the top half of the tire pressure valve, it snaps onto the sending unit inside the tire. Keep the sending unit inside the tire or you will need to get the TPMS set which is more hassle.
If you got the car from a dealer get them to fix it.
Old Mar 19, 2013 | 05:31 PM
Mrmiata's Avatar
I don't have mine handy for quick reference on the lenth of the stem "housing".. but could the valve stem core just need screwed back in?
Old Mar 19, 2013 | 05:46 PM
No, Schrader valve stems are screwed up tight to a seat which has a seal on it. If it is not screwed in all the way it will leak air.
You can
see that the part missing is the portion that the dust cap screws onto.
Old Mar 19, 2013 | 06:56 PM
MyFire91's Avatar
I got the car at a Nissan dealership. Even though my car is not a nissan, can i still make them fix it?
Old Mar 19, 2013 | 10:26 PM
It appears that the cap was made of incompatible material (cheap steel) and caused corrosion on the aluminum stem that allowed the damage. I would get it replaced ASAP. And check the rest of the stems for damage as well. The safest cap to use is plastic.
James
Old Mar 20, 2013 | 11:34 AM
MyFire91's Avatar
yeah i dropped it off at the dealer today so lets see what happens later. I will be replacing them with plastic caps as soon as i can. thank you
Old Mar 20, 2013 | 09:28 PM
MyFire91's Avatar
so the dealer changed the tire valve but they said they didnt have a tpms valve so the light will stay on since its a nissan dealer. Now i gotta do that thing i found on this forum to make that light on the dash turn off. thanks for the tips guys.
Old Mar 20, 2013 | 09:46 PM
Mrmiata's Avatar
If you plan on actually fixing it anytime soon.. a nice round patch of electrical tape will take it out of sight - out of mind. I would think most any retail tire dealer would be able to hook you up with a fix at a reasonable price. $20-$30 dollar range?
Old Mar 20, 2013 | 10:06 PM
You just need the rebuild kit.
Wrong.
Old Mar 20, 2013 | 10:18 PM
No I think he needs the stem itself, according to the pic, which is usually part of the TPMS assembly.
Old Mar 20, 2013 | 10:24 PM
Mrmiata's Avatar
Oh wait.. just realized ours aren't the little "clip to stem" type you see on Ebay are they? Never mind on the easy tire shop fix. I hope you got the sensor back in hand since reportedly the frequency ID (needed for programming a new one) is stamped on them.
Old Mar 20, 2013 | 10:32 PM
You are correct of course, stupid me.
Is it possible to take the stem from a sensor with a dead battery and snap it on to this sensor?
It would save money for sure and all the sensors would stay the same age and condition.
Old Mar 20, 2013 | 11:14 PM
Mrmiata's Avatar
If we can hit a 95% rate off memory recall at our age 180.. we're doing great.. LOL.
I'm thinking ours are a one piece design aren't they?
usprb1976
Apr 4, 2024 04:57 PM
Jonacross
20
Jul 17, 2017 11:19 PM
minimayhem
16
Aug 23, 2016 07:47 AM
ATX SRT-6
Sep 11, 2015 09:19 AM
jaesa
Sep 7, 2015 01:50 PM
