spungy brake pedal just out of winter storage
Old May 8, 2013 | 10:11 PM
rossthebossfromlacrosse's Avatar
Default spungy brake pedal just out of winter storage
Purchased our 05 roadster back on laborday of 12 put about 2600 miles on before November . put er in storage for the winter. got her out yesterday and when I first stopped the car the brake pedal went over half way to the floor. brakes are working fine and can be pumped slightly to get the pedal to the top where it should be. no fluid has leaked over winter.......is there a vaceum leak or what? please help if you can....thanks ross.
Old May 8, 2013 | 10:23 PM
Easley15's Avatar
Default Re: spungy brake pedal just out of winter storage
well vacuum leak would cause you to have no pressure wouldnt it?? Get the brakes bleed get some new fluid and see what the does for you!
Old May 8, 2013 | 10:35 PM
Mrmiata's Avatar
Vacuum leak = stopping a tank by dragging a stick.. LOL.
You'll have a solid pedal.. but you can stand on top of it and hope it slows down..
Pedal travel and pumping to build with no leaks at wheels or otherwise would be a sign of the master cylinder loosing the pressure.
Old May 8, 2013 | 10:38 PM
Easley15's Avatar
so are you agreeing or disagreeing with the brake bleed
Old May 8, 2013 | 10:43 PM
Mrmiata's Avatar
I'm agreeing that's at least where I'd start..
Old May 8, 2013 | 11:06 PM
itsky's Avatar
I had a similar issue with my roadster recently. The BAS/ESP light was on and the brake peddle had a lot of play. I had the brake fluid flushed, filled, and bled, and no problems since then. Cost was about $100 (including a full alignment).
RED DOG
44
Oct 27, 2020 09:00 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
Speedy4x4
Sep 23, 2015 11:42 AM
xjken
Sep 13, 2015 10:18 PM
