Brake lights short
Old May 7, 2019 | 08:50 PM
Jdabs's Avatar
Default Brake lights short
My break lights short the sec you press the break. A mechanic told me it’s the break light switch. Is there a way to replace that? And why exactly do you have to replace?
Old May 7, 2019 | 08:53 PM
Default Re: Break lights short
Here you say it is the BRAKE switch, yet in your other post you are looking for bulb/socket/connector? Which is it? What fuse is blown?
Old May 7, 2019 | 09:14 PM
Jdabs's Avatar
Sorry for the confusion. It is the break switch, but I also need a new bulb socket for the rear right tail light/break light
Old May 7, 2019 | 09:46 PM
So why do you think it is the BRAKE switch? It is located above the brake pedal on the brake pedal arm.
Old May 8, 2019 | 05:54 AM
Jdabs's Avatar
The mechanic told me I need to replace the whole break pump is that true? (The break lights weren’t working before the socket broke , it’s not the socket)
Old May 8, 2019 | 09:16 AM
Break pump? Do you mean brake lever?
You has better explain your problem more thoroughly, you know what it is but we can only guess what you mean.
The BRAKE (another hint) switch is easy to replace, take it out and look at it first though. Although you might want one handy in case it is the problem, they are cheap.
I am guessing the socket has a number and a makers name on it, look for it.
Old May 8, 2019 | 12:39 PM
Jdabs's Avatar
Thank you. Where is the brake switch exactly?
Old May 8, 2019 | 12:58 PM
maggy55's Avatar
The switch is inside the car behind the brake pedal.
Old May 8, 2019 | 01:10 PM
maggy55's Avatar
See this thread'
https://www.crossfireforum.org/forum...-location.html
Old May 9, 2019 | 03:19 PM
How do you KNOW the lights are "shorting" when you press the brake?
What I am getting at, is I'm not sure what we are chasing here.
Old May 17, 2019 | 08:38 AM
Jdabs's Avatar
I opened up my dash to check out the brake light and I’m pretty sure it’s missing. I had a problem with my brake lights shorting. The problem is I dont see the wires that connect to the break light switch. Does anyone have a picture or something this way I can be more clear about what’s going on? Thank you!!
Space coupe
18
May 12, 2020 01:22 PM
DadsXF
Jan 5, 2020 06:39 PM
ZERACER
Sep 26, 2018 08:26 PM
jnwert
Sep 7, 2018 05:53 PM
loudrango
Sep 1, 2018 10:41 AM
