Wheel spacers with stock rims question
Hi everyone, first post here. I’m interested in putting wheel spacers on my 05 crossfire convertible with the stock rims.
Ive been thinking 40-50mm spacers, but my mechanic told me it would likely make the tires wear a little quicker because the car would “sag” a bit with the wider base and possibly put a weird angle on the tires.
My question is: has anyone done something like this, and did you notice any negative effects in terms of tire wear or anything else?
Thanks for the quick reply @amx1397 ,
would I have that same problem with the bolts breaking if I used a smaller spacer, like 15-20 mm?
first of all no one makes lug bolts long enough for a 40 to 50 mm spacer ,, you would have to get this type of lug wheel spacers https://www.youtube.com/watch?v=d9h9pcII8q8 no the car would not sag,,, but it is so unsafe that if you went too fast around a conner your spacer bolts might brake you see with out Hubcentric spacers your wheel is held on centered by the bolts,, so don't do it,,,.jim
mrphotoman
May 31, 2013 10:55 PM
Garrebearr
Oct 7, 2012 04:53 PM
crosseduphwy101
Sep 21, 2012 03:25 PM
Infinite
Feb 26, 2010 07:43 AM
