Blinking TMPS light
Old Jul 27, 2019 | 12:50 PM
maggy13's Avatar
Default Blinking TMPS light
My 2005 crossfire has tires that are 6 years old, the sensor light is blinking but the tire pressure is good on all 4 tires. I have never replaced the batteries or the TMPS on the tires. Since the care is 14 years old should I replace them when I get new tires?
If so should I purchase them and carry them to my tire guy? Where is the best place to purchase them?
Old Jul 27, 2019 | 02:32 PM
KDW4Him's Avatar
Default Re: Blinking TMPS light
The easiest is to do all at the time tires get replaced. That is what I did, see my sig file TPMS 101 post. I suspect the fact the light blinks is different than a solid light so you may have something else going on. Meaning it could be the TPMS receiver in the car that is the issue. I can't find right now what the flashing means.
Old Jul 27, 2019 | 02:34 PM
KDW4Him's Avatar
PS; You will get advice and the link on how to disable the light. I'm not one of those. I believe modifying the light to never work devalues the car.
Old Jul 28, 2019 | 05:40 PM
I know on many of the newer car models, a blinking TPMS light indicates a tire sensor issue. But if I remember, since the Crossfire TPMS system is an early design, there shouldn't be a blinking light for any condition. All we get is a solid light indicating some sort of issue, which has to be diagnosed. LOW or HIGH tire pressure, sensor fault, TPMS system fault. Did I miss anything?
Old Jul 29, 2019 | 11:44 AM
The sensors only indicate low pressure in a tire, sensor battery or system failure and not high pressure.
The reason for a flashing light is a mystery to me, I have never seen that mentioned before.
Old Jul 29, 2019 | 01:20 PM
I remember having a light on the original Red Roadster. I had high pressure in one tire.
Jam 45 or more pounds in a tire and drive a mile or so - I'd bet ya the light will come on.
Just remember, the sensor does not transmit sitting still; ya gotta drive a bit for it to trigger.
I know it's been nine years, but I really am sure they will trigger on high pressure.
Old Aug 1, 2019 | 06:21 PM
maggy13's Avatar
Found the fix! Turned out to be a bad battery. I replaced the battery, light still was flashing so I followed your advice and actually drove the car. Within 2 blocks the light went off.
I feel like a pinch of goat..... because i ordered a new set of tires thinking my tires were bad, anyway live and learn.............Thanks for the good advice!
Old Aug 2, 2019 | 10:01 AM
We may have learned something new with your issue. A "blinking" TPMS light is another indicator of a weak battery. Who Knew!!
thegoalie
Apr 24, 2026 08:51 PM
billy
Aug 6, 2018 08:56 PM
CoupeGirl
Feb 16, 2008 11:46 AM
mdpennywitt
Apr 4, 2007 12:35 PM
CHERYLCARSON1
Mar 8, 2007 05:23 PM
