New Tire Sensors: Low tire pressure light stays on
Just purchased Four New Tries and Sensors at Discount Tire, but the Low tire pressure light stays on, even after driving from Fort Worth to Dallas, and back.
Is there a step that must be done after these are installed?
Another Option - You may want to see if a Crossfire Forum Member is located close to you that has the DRB/III software capability. That member could align the wheel sensors to the TPMS Module & clear the Tire Pressure warning Light.
Discount Tire does NOT have the capability to program the new wheel sensors to the TPMS Module
Were the sensors still working when replaced? If they were they should have cloned them. Any tire shop should be able to clone them. I would call them they should still have the old sensors (usually have recycle bin for them). If the battery in the sensors were dead (was TPMS light on dash on) cloning is not possible. I would also ask for refund of some kind if they cannot clone them. If they cannot clone them or program new ones you just paid over $200 for new sensors for no reason. They are supposed to be experts in tires and tire systems. Hopefully you can locate someone that can program the new sensors (if they installed correct sensors). If not, you can always disconnect the warning light that runs through the dome light. You can find out how to disconnect the wire in index of problems and repairs. GOOD LUCK
I called and they said to stop by, and they will reset them, we'll see,
otherwise, it was $200 for four useless sensors, and the laptop rubber foot goes back over the light.
To disable the TPMS, watch this:
Read through this post: https://www.crossfireforum.org/forum...ms-issues.html
There are two very good PDFs on the TPMS; Clint's is very informative.
bluemax
Jan 15, 2022 01:26 PM
phyla
May 4, 2018 06:08 PM
