Air Bag Recall
on
Re: Air Bag Recall
OK, the wait is over. Have car back and light is off.
Had a large number of "false" codes but once cleared they stayed gone and light is off (went on some errands and still off).
For the AR I was given a list of the "false" codes which were what I might expect, all B codes.:
b10f5, b1003, b1122, b1123, b1102, b1103, b210d, b210a
Am told a B210D is "low battery" and can cause all sorts to other codes. Since the list above includes both high and low values, it would not surprise me, kind of thing I would expect from a bad ground.
But bottom line is that codes were declared "false", are now cleared, and the airbag light is off.
Any guesses why this happened ?
Purely a guess, could the tech have left the NEG cable on initially, then the code set, then they all went nuts with key on trying to figure out why the light was on and drained the battery? OK, who knows really? PLEASE make sure your SRS system does its 'Self Test' during startup. That will tell you if they 'fixed' it or just fixed the dash light (if you know what I mean). Hope your back 100%!
on
Re: Air Bag Recall
Re: Air Bag Recall
I feel that I believe that the air bags are probably just fine in all of these years and models, neither of mine have ever deployed and if either was bad that probably should have happened in all this time,
plus recalls are scams to get the car at the dealer to sell parts and services and even get you to trade yours in
Re: Air Bag Recall
Re: Air Bag Recall
Just wondering how the airbag recall turned out for the 06-07 Cross fire owners. Did Chrysler eventually get all the replacement stock and did everyone with recalled cars get new investors installed? Did they ever expand the recall to the passengers side ? My son's Mazda 6 started with a driver's side only recall. After they replaced it they replaced it a second time because we found out the first replacement was an identical part to the ones that were exploding but new.. On the same day they installed the second drivers side updated airbag module, they also added the passenger side to the recall....so that was changed with the revised module,too. I am totally convinced that my two Buicks, that were never recalled are most likely affected too but because there have yet to be any explosions in those two cars, they go unrecalled.Just a bit feeling. How many of you Cross fire owners actually have received your replacements as of now, December 2018?
Re: Air Bag Recall
Re: Air Bag Recall
on
Re: Air Bag Recall
on
81's
09-13-2015 04:34 PM
