First thing to do
Old Nov 13, 2014 | 10:32 PM
JEFASOLD's Avatar
Default First thing to do
After seeing all the problems with start no start, idle issues, etc. here is a suggestion for everybody. Go to Harbor Freight and buy an OBDII reader, get as good as you can afford, they range from $59 to $199, then buy the battery and alternator tester. They won't be the answer for absolutely every problem but for the most part, they will give you some direction to resolving your problem. Without some information, we often make a simple thing more complicated than it needs to be. Then come to the forum and ask the smart guys what they think. LOL
Old Nov 13, 2014 | 10:34 PM
Default Re: First thing to do
I think you mean OBDII?
Originally Posted by JEFASOLD
After seeing all the problems with start no start, idle issues, etc. here is a suggestion for everybody. Go to Harbor Freight and buy an OBDI reader, get as good as you can afford, they range from $59 to $199,
Old Nov 13, 2014 | 10:53 PM
JEFASOLD's Avatar
Yeah, that's what I meant, so I fixed it, thanks.
Old Nov 14, 2014 | 01:18 PM
07aeroblue's Avatar
You can also buy a cheap bluetooth OBDII reader on eBay (13 bucks shipped) and pay the 5 bucks for the Torque app on android. I keep mine plugged in all the time, works like a charm.
Old Nov 14, 2014 | 01:27 PM
lildaddym's Avatar
+1 on Torque...works really well...
Old Nov 14, 2014 | 02:12 PM
Speedy4x4's Avatar
Default
I like torque.
It gives factory and aftermarket codes
Old Nov 16, 2014 | 06:31 PM
nickwe21's Avatar
From what I understand this thread points to three popular issues....Dead battery, mystery no start (sticky) and Crank Position Censor replacement (also a sticky).
All known problems...
Old Nov 16, 2014 | 07:37 PM
A reader will help, as well as a voltage meter....but a star dos system isn't cheap enough to buy for most people....lol
Old Nov 16, 2014 | 07:46 PM
Mrmiata's Avatar
Speaking of.. guess with this snow and cold temps there's nothing better to do than open that box from Lantana and start the learning procedure.. LOL.
Old Nov 16, 2014 | 07:53 PM
There you. I have found a few systems on ebay, but I know not enough to know what hell I would be buying.....so I have stayed away....
Old Nov 17, 2014 | 01:31 PM
Goldwing's Avatar
The Crossfire is so reliable, who needs diagnostic devices? Only problems were the I/C pump (well known), a popped plenum plug (OBDII showed med the codes and scared the crap out of me - thought I blew the s/c), and a haywire transmission cable (do not need a code reader when you cannot go into 1st or 2nd). Yes, I did buy the OBDII for problem #2 and as the owner of three Audis it has come in very useful.
fastfred
Nov 5, 2018 09:47 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
debradegiovanni
Sep 27, 2015 09:39 AM
